1997 Bonneville misfire
Posted: Sun Jun 29, 2014 12:36 pm
by zigger21
I have a problem with Bonneville it comes up with a random misfire and I don't know where to begin, spark plug, wires, egr valve, fuel injector, Oxygen sensor, Vacuum Leak, coil or Ignition Module? I dont want to throw parts at it and hope it works. What is the most common for a P300 misfire code?? Thanks in advance.
Re: 1997 Bonneville misfire
Posted: Sun Jun 29, 2014 1:48 pm
by Jfridge92
Start with the easy things first. How old are the plugs and wires? If they're old, try replacing those first.
Also, I'm assuming your car is an se (non-supercharged?). How many miles are on it, and have the intake gaskets ever been done?
Check for vacuum leaks when the car is cold by spraying some carb cleaner around all the vacuum lines and the intake manifold, if the idle changes you've got a leak.
Posted: Mon Jun 30, 2014 3:53 pm
by human
Ignition coils are often a culprit. I've had to deal with that on three of the last four cars I've owned. If any of your coils don't have numbers on them, they've probably already been replaced. The factory coils have numbers on them, indicating which cylinders they're connected to. Try replacing the older ones first.
Posted: Tue Jul 01, 2014 12:41 am
by SuperHbody
I agree with the coil suggestion. If you're handy with a multimeter you can take resistance readings that can tell you which one is bad as well as test the plug wires. Makes it easier than throwing parts at it.
