Oops...
- J Wikoff
- Year and Trim: 1992 SSE
Oops...
I was getting something fairly large out of the backseat of the G8, and part of its metal frame rubbed the edge of the door jamb/fender. How can I make that disappear for cheap? It's through the clear and the paint in some spots.
- repinS
- Moderator
- Year and Trim: 09 G8 GT
Re: Oops...
I would be willing to bet that it can look 90% better with just a good polish. Maybe even a bit better with some touch up paint and wetsanding beforehand. Detailing experts (Ryan) could probably confirm.
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
Re: Oops...
If it is through the clear / paint then touch up paint would be the cheapest and best route to go with it. Build it up with a couple layers, lightly wet sand it down, then polish it and that should take care of it.
- J Wikoff
Re: Oops...
A better pic might be needed to fully show it, but a general polish isn't going to help much. Maybe 30% at most. That was my first thought.
- J Wikoff
Re: Oops...
Can you recommend a wet sanding process? Never done it.
rfoster
- Year and Trim: 02 SSEi: :(
02 Elantra GT: getting me by - Location: Indianapolis, IN
Re: Oops...
I would personally look over at AutoGeek forums for some wetsanding tutorials. In the meantime, I'll be looking.
EDIT found a video and such by Mike Phillips. To view, you may or may not have to have an account. clicky
- RJolly87
Re: Oops...
I am gonna have to call the insurance card on this one. Should fall under comprehensive.
May as well get it fixed right, because you are gonna see it from the way you describe it.
- repinS
- Moderator
Re: Oops...
The touch up paint before wetsand/polish method sure worked well when Ryan did my GXP:
There were bits of the damage that went right through the paint. Almost undetectable, the only person who would have known work was done would have been myself or Ryan.
- harofreak00
Re: Oops...
fake fix! different plates!!
jk
jk
Re: Oops...
Sanding on a corner like that is never a good idea though. The paint around it's always thinner, and you run a huge risk of going right through it. I'd dab on touch-up paint and see if you can polish it a bit.
So what were you removing from the car? This is a must-know.
- repinS
- Moderator
Re: Oops...
I'll never live that one downharofreak00 wrote:fake fix! different plates!!
jk
I'm guessing you missed the part of my damage on the bumper, at the edge around the headlight. Wetsanding can work just fine.00Beast wrote:Sanding on a corner like that is never a good idea though. The paint around it's always thinner, and you run a huge risk of going right through it. I'd dab on touch-up paint and see if you can polish it a bit.
Re: Oops...
I'm guessing Ryan went right up to the corner on both sides?
- J Wikoff
Re: Oops...
Yeah, being on the bend of a 1-2mm radius was my primary concern, really.
What I was getting out was this. The power company told me the power would be out till late Wednesday night. So I drove two hours and picked up my sister's generator. It went in fine after taking the seat bottom out. Got home, got it out in a not quite as smooth manner. The power came back on an hour later...
