WOT stumble
Abbby
- SSE Member
- Year and Trim: 2003 SLE 208,000 miles
2003 SLE 196,000 miles
WOT stumble
I have two 2003 Bonnevilles and they both do this. If I floor it at around 60mph once the RPM's get to about 4000 the engine starts stumbling/surging. They both run great and get good gas mileage.
- Alpine_jake
Re: WOT stumble
codes? your saying its missfiring?
l67 swap; 3'DP, power log, CAI, 10.5 wires, 3.5" pulley, autolite 104s, canned tune, 180 thermo, 2 Alpine type Xs, ARC Audio XDi 2000, Big three-0/1 , couple Red Tops, alpine x303, cleared lights, custom trunk.
Abbby
- SSE Member
Re: WOT stumble
No codes. Not sure if it is misfire but definetly something not right. Kind of like bumping up against a rev limiter.
Re: WOT stumble
This is in the common problems doc:
Loss of power in higher RPM’s
Problem: The car has a loss of power at higher RPM’s, stalls and chokes out when giving throttle.
Solution: The catalytic converter is plugged, not allowing the exhaust gases to release from the engine. Replacement cat is required.
Estimated Cost: $50-70 for aftermarket cat (OEM cats cost hundreds), $20-50 for installation labor.
- Archon
Re: WOT stumble
May also want to check for vacuum leaks, and fuel pressure at the higher rpms. If you haven't lately, it wouldn't hurt to replace the fuel filter.
Abbby
- SSE Member
Re: WOT stumble
Do you know if the $50-70 aftermarket is a universal one or bolt up? Where would one buy this. Be nice to have bolt up versus universal that needs modification to fit.
