Smaller K & N Filter needed
- ytd1861
- Year and Trim: 2003 Bonneville SE -normally aspirated- 4 door
I installed my FWI today, but on my 03 Bonneville SE, the stock 9" cone air filter that came with the Intense kit is too long. Anyone else have this issue and go with a smaller length K&N?
What size did you use? (installing thru the headlight... I Do not want to bother with fender well removal)
This is what I installed..... http://intense-racing.com/Merchant2/mer ... _Induction
D.T.
- nos4blood70
- Year and Trim: 2003 SLE
Re: Smaller K & N Filter needed
If you have the means I would suggest trying to do the fenderwell method. Much easier. You can manipulate it easier.
- ytd1861
I don't have a close source for the tabs that are very prone to breaking when removing the fender, and the other issue is the apartment complex I live at has a strict tolerance of no working on cars. I was able to do about 3 hours work at a friends place today but its very rare to be able to do that.
I wish Volant made a box for my car. I've had 2 of theirs on GMC/Chevy trucks and they were fantastic and true "cold air" boxes.
D.T.
- mylittleblackbird
- Posts like a Northstar
- Year and Trim: 1995 LX(went to the shredder)*sniffle*
1999 SE - Location: Muscatine, IA
Breaking tabs in the fender?
For what it's worth, you'll only break them once.
I have a Bonneville, it's white and N/A!
Mod List: Hood and Fender "adjustment" - "Enhanced" A/C compressor clutch - Extra loud PS Pump - Mega sensitive CKPS - Audible Rear Drums - Lowered headliner - Custom stained upholstery - "Brown Devil" weight reduction kit - Low Friction Belt. More to come!
- ytd1861
I'm going to get a shorter and a bit thinner filter then run it to behind the headlight. I found one at Summit which will fit just fine.
D.T.
What size inlet on the filter? I run a 3.5" inlet 7" cone K&N RU-3130. my local Advance auto parts store stocks them ~$35
S
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
- SSEiMan01
- Year and Trim: .
03 PAU - Location: DeKalb, IL
The 9" will fit in there, it won't move around in there, but it will fit with some finagling. I almost preferred to have the 9" in there because of that.
James May wrote:Hello.
- ytd1861
Shane "RedZMonte":
Same 3.5" inlet as yours but only 5" tall. Should be easier to get it in and out for cleaning. My car won't ever be used for racing on the strip, its just a daily driver and I'm adding some mods for more play around power and some MPG if produced
SSEiMan01: You obviously have more patience than me. I've got a temper and if things don't bolt-up pretty quick, I get wound pretty tight. A smaller, easier to install filter is just what I need. ha ha
D.T.
- SSEiMan01
- Year and Trim: .
I had Wake put the filter in mine.
I'm very impatient too.
my filter comes in and out very easy and has room to spare, lower the front splash guard on from the lower part of the bumper and its out.. 5 min job to R&R.
Shane "RedZMonte"
- Trinity
- GXP Member
- Year and Trim: 2002 SSEI "Twitch"
Intense LIII - Location: IL
Any autoparts store will let you work on cars there as long as you buy from them.ytd1861 wrote:I don't have a close source for the tabs that are very prone to breaking when removing the fender, and the other issue is the apartment complex I live at has a strict tolerance of no working on cars. I was able to do about 3 hours work at a friends place today but its very rare to be able to do that.
2002 SSEI "Twitch"
INTENSE™ Fenderwell Intake Kit
INTENSE™ Modular Pulley System with 3.40" Pulley -
SD Headers H-Flow Cat
WB 255 Siemens 60.0 (65.0) pound/hour Fuel Injectors
Yella Terra 1.9 90# Manley Retainers
L32 LIM & Gen V Blower N* TB
- SSEiMan01
- Year and Trim: .
Depends on what you need to do... There could always be a potential issue of liability. We change batteries and wiper blades in our parking lot for customers, but if they need some major job done some places might be leery.
But yeah, an intake, I wouldn't think that would be a problem. I put mine (on the GXP) on in the school parking garage.
- ytd1861
I'm just going with the smaller size filter. It should make removal later to clean it a bit simpler too. This isn't anything to get worked up about in my book...so long as it works, I'm good with it.
D.T.
- Trinity
- GXP Member
Ya, I'm not thinking jack-stands overnight or anything lol I've done brakes, radiators, plugs/wires etc. I know my Oreilly guy pretty well tho.SSEiMan01 wrote:Depends on what you need to do... There could always be a potential issue of liability. We change batteries and wiper blades in our parking lot for customers, but if they need some major job done some places might be leery.
2002 SSEI "Twitch"
