New engine tune up
Posted: Sat Mar 16, 2013 10:37 am
by Weekender
Hey guys, bought a used engine for my 99 in November. other one locked up. had loaned it to my 78 year old father who had the oil chaged at walmart while he had it. with ut asking me., wll he meant well... wrong oil and it locked up. anyway getting ready to do plugs and wires, have read the threads o what to u, gutting air box and doing tran filter and fluid.any suggestions
or tips. also i am getting 22 to 24 mpg now is that bad?
Re: New engine tune up
Posted: Sun Mar 17, 2013 12:10 am
by Jfridge92
Is that 22-24 city, highway, or mixed? If it's city, that's great mileage. Highway isn't completely terrible, but pretty low. If it's mixed, and depending on your driving habits, that sounds about right. I usually get around 18-19 around town, and around 30 on the highway. If you have a lead foot though, of course those numbers will be lower. How many miles are on the car/new engine? How are the O2 sensors?
From our very own Ed (00beast)
  • 1987-2005 Bonneville / Buick 3800 Maintenance List
    Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease or Amsoil Grease recommended)
    PCV Valve Every 30k
    Fuel Filter Every 15-25k (Purolator, AC Delco, WIX) http://www.pontiacbonnevilleclub.com/fo ... 45&t=23215
    Spark Plugs Every 30-50k (NGK TR55, AC Delco 41-101 or Autolite 605) (Never Bosch)
    Oil & Filter Every 5-6k or Every 6 months (Valvoline SYNPower, Pennzoil Platinum, or Amsoil )(Mobil1, Purolator PureONE, Amsoil EaO, K&N or WIX) (Never Fram) viewtopic.php?f=45&t=214
    *Conventional Oil Every 3k/3 months(API SM/SN rating) (WIX (Napa), Delco or Purolator filter)
    Tires: Check Inflation Pressure & Visually Inspect Monthly Rotate Every 6-8,000 Miles
    Transmission Flush or Pan Drop Every 15-20k (Always make sure filter is changed when flushed) viewtopic.php?f=45&t=10193
    Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Mixes-With-Any Coolant Only) (Never Dexcool)
    Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only) viewtopic.php?f=45&t=13626
    Brake Fluid Flush 3yr/50k
    Power Steering Fluid Replacement/Flush Every 100k or 5 years
    *Special Considerations*
    All Series II/III 3800's RPO's: L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
1/25/2013 by 00Beast
Posted: Mon Mar 18, 2013 9:13 am
by MattStrike
I would recommend things to do now (if the motor came from a junkyard) to use a MAF sensor cleaner to clean out the throttle body (use a soft bristled hobby paint brush on the sensor itself) and change the LIM gaskets (unless they are metal framed gaskets, which won't have the problem) and put a new UIM on. Then run a can of seafoam or your preferred fuel injector cleaner through the next fillup.
