Boost gauge sits at -70
bonnevillen
Year and Trim: 1993 Bonneville SSEi
Post by bonnevillen »
The boost gauge on my 96 SSEi sits at -70 rather then at 0 when I am at idle. This happened on my 97 as well. Is this a common problem on the supercharged 3800 and what is the fix. thanks
J Wikoff
Re: Boost gauge sits at -70
Post by J Wikoff »
That's exactly what it should be doing. Doesn't sound like anything is wrong.
FasGP
Year and Trim: Pullied Clean 2k Black SSEi...
Post by FasGP »
At idle, it reads normal vacuum of the engine, thus negative value. It is correct.
