Where Is The Turn Signal Flasher At?
Blown93SSEi
Year and Trim: Dark Green 1997 SSEi
Post by Blown93SSEi »
n/t
Jacob, Dark Green 1997 SSEi "The Green Lantern" Over 268,000 Miles and Still Going Strong!
Mods/Stuff: INTENSE! FWI, ScanGauge 2, Mobil 1 HM Oil, Valvoline HM Transmission Fluid, Mildly Tuned PCM, Drilled 180 Thermostat, Cleared Corners, Silverstars, Chrome T-Stars, NGK Iridium Plugs, NAPA Belden Wires.
Mad Myche
Re: Where Is The Turn Signal Flasher At?
Post by Mad Myche »
Pull the cover down below the dash on the driver side. Directionals is outboard from the steering column, and the hazards are inboard. They are both metallic can flashers, easy to spot with a flashlight
~Mad Myche from Around Milwaukee~ wrote:Contrary to what some may think... I have not lost touch with reality, rather; reality cannot keep up with me
Blown93SSEi
Thanks a bunch. Got it done last night. Took a few moments to see it almost hidden by the fuse panel (felt dumb for a sec lol).
Turn signal work again!
Mad Myche
Post by Mad Myche »
You're welcome
I replaced mine a month ago after it was blinking like once every 5 seconds or so, but not before getting pulled over (and sobriety checked due to the time) because officer didn't see it blink...
