Are there any for an SII L67?
I was in the mist of trying to connect the rear one (between engine and tranny) and noticed that the connector won't fit in the sensor. The front is definitely a smaller connector when compared to the rear. Are the sensors actually different in any way? I cannot seem to find any different designation on rock auto or ebay.
I am hoping that I don't have to remove the sensor and that I can simply replace the rear connector for a front connector and be done with it.
Front and Rear Knock Sensor Differences
SC-Type
- Year and Trim: 1988 Buick Lesabre T-Type
- sandrock
- Retired Gearhead
Re: Front and Rear Knock Sensor Differences
No differences at all. The rear sensor has an extension on it that makes it easier to connect, and even it is a plugin.
SC-Type
ummm, never noticed an extension while removing the harness. I'll check my pile of wires and see if anything in lingering. That would make sense because originally the wire was too short, so I ended up extending it. I thought it was too short because of the routing I chose for the main harness, but the extension makes sense. And it'll also explain why the connector doesnt want to insert into the sensor.
Thanks!
Thanks!
- MattStrike
- Year and Trim: '99 Montana
I had the same problem. Except I removed the sensor and cut off the connector before I figured it out.
- harofreak00
SC-Type
Well dont lead me on with just a picture! Sell me the *dang* thing!!!harofreak00 wrote:
Unless thats a generic photo you found.
- harofreak00
No that's my pic.
