power?!
Posted: Sat Apr 07, 2012 11:24 pm
by bonnie33
i have a 96 Bonneville se, it seems like there should be more power, i take off from a stop and it seems there should be at least a couple squeaks out of the tires but nothing at all, anyone else have this problem?
Re: power?!
Posted: Sat Apr 07, 2012 11:49 pm
by 94SilverSSEi
Have you tried turning traction control off?
Or really putting petal to the metal?
Re: power?!
Posted: Sun Apr 08, 2012 5:32 pm
by Ludichris
How long have you owned the car? What maintenance items have you done to the car up until this point? If you haven't had it for very long, what maintenance items do you know for certain the previous owner did? What condition are the plugs and wires in? Air filter? MAF sensor? O2 sensors? Exhaust system? Etc. etc. etc. Tell us about what's been done to the car recently.
Re: power?!
Posted: Sun Apr 08, 2012 9:59 pm
  • 1987-2005 Bonneville / Buick 3800 Maintenance List
    Run Seafoam, Chevron Techron or Gumout Regane through gasoline every 5,000 miles.
    Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease or Amsoil Grease recommended)
    PCV Valve Every 30k
    Fuel Filter Every 15-25k (Purolator, AC Delco, WIX) http://www.pontiacbonnevilleclub.com/fo ... 45&t=23215
    Spark Plugs Every 30-50k (NGK TR55, AC Delco 41-101 or Autolite 605) (Never Bosch)
    Oil & Filter Every 5-6k or Every 6 months (Valvoline SYNPower, Pennzoil Platinum, or Amsoil )(Mobil1, Purolator PureONE, Amsoil EaO, K&N or WIX) (Never Fram) viewtopic.php?f=45&t=214
    *Conventional Oil Every 3k/3 months(API SM/SN rating) (WIX (Napa), Delco or Purolator filter)
    Tires: Check Inflation Pressure & Visually Inspect Monthly Rotate Every 6-8,000 Miles
    Transmission Flush or Pan Drop Every 15-20k (Always make sure filter is changed when flushed) viewtopic.php?f=45&t=10193
    Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Mixes-With-Any Coolant Only) (Never Dexcool)
    Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only) viewtopic.php?f=45&t=13626
    Brake Fluid Flush 3yr/50k
    Power Steering Fluid Replacement/Flush Every 100k or 5 years
    *Special Considerations*
    All Series II/III 3800's RPO's: L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
Re: power?!
Posted: Sun Apr 08, 2012 10:10 pm
by nos4blood70
:withstupid:
Could be anything really.
Re: power?!
Posted: Mon Apr 09, 2012 4:09 pm
by bonnie33
ive had the car for exactly a year now, it has new engine about 70,000 miles on it, but the thing is i dont know any of the maintenance done to it, i looked at the air filter and its terrible so im getting one, but id have to check everything else, what happens is i tried putting it to the boards with tcs off and no tire squeak or anything, barely puts you back in your seat. im thinking its the higher gear ratio.
Re: power?!
Posted: Mon Apr 09, 2012 6:59 pm
by repinS
I'd be curious to see what final drive ratio you have.
Does anyone know what RPO codes we need to be looking at? Or better yet, what are your RPM'S at 60mph?
Re: power?!
Posted: Mon Apr 09, 2012 11:46 pm
by 94SilverSSEi
repinS wrote:I'd be curious to see what final drive ratio you have.
FW2 or F17, I believe.
