power?!
bonnie33
- LE Member
- Year and Trim: 1996 bonneville se
2003 bonneville se
power?!
i have a 96 Bonneville se, it seems like there should be more power, i take off from a stop and it seems there should be at least a couple squeaks out of the tires but nothing at all, anyone else have this problem?
94SilverSSEi
68 w/400
Re: power?!
Have you tried turning traction control off?
Or really putting petal to the metal?
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
- Ludichris
- Posts like an LG3
- Year and Trim: 2005 SE
Re: power?!
How long have you owned the car? What maintenance items have you done to the car up until this point? If you haven't had it for very long, what maintenance items do you know for certain the previous owner did? What condition are the plugs and wires in? Air filter? MAF sensor? O2 sensors? Exhaust system? Etc. etc. etc. Tell us about what's been done to the car recently.
My 4th Bonnie...I love these cars!
Re: power?!
- 1987-2005 Bonneville / Buick 3800 Maintenance List
Run Seafoam, Chevron Techron or Gumout Regane through gasoline every 5,000 miles.
Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease or Amsoil Grease recommended)
Air Filter Every 15k (Amsoil EaA, Purolator PureONE)
PCV Valve Every 30k
MAF Sensor Element Cleaning/TB Cleaning Every 50k viewtopic.php?f=48&t=1661
Fuel Filter Every 15-25k (Purolator, AC Delco, WIX) http://www.pontiacbonnevilleclub.com/fo ... 45&t=23215
Spark Plugs Every 30-50k (NGK TR55, AC Delco 41-101 or Autolite 605) (Never Bosch)
Ignition Wires Every 30-50k (Napa Belden, AC Delco, Autolite Pro, NGK) (Never Taylor or Bosch)
Oil & Filter Every 5-6k or Every 6 months (Valvoline SYNPower, Pennzoil Platinum, or Amsoil )(Mobil1, Purolator PureONE, Amsoil EaO, K&N or WIX) (Never Fram) viewtopic.php?f=45&t=214
*Conventional Oil Every 3k/3 months(API SM/SN rating) (WIX (Napa), Delco or Purolator filter)
Tires: Check Inflation Pressure & Visually Inspect Monthly Rotate Every 6-8,000 Miles
Transmission Flush or Pan Drop Every 15-20k (Always make sure filter is changed when flushed) viewtopic.php?f=45&t=10193
Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Mixes-With-Any Coolant Only) (Never Dexcool)
Oxygen Sensor Every 80-100k (30k for non-heated) (AC Delco or Denso) (Absolutely never Bosch) viewtopic.php?f=48&t=794
Accessory Belt Inspect every 15k, replace every 100k, or as needed
Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only) viewtopic.php?f=45&t=13626
Evap Core Cleaning Whenever Needed (Note: 99 and older only) viewtopic.php?f=45&t=2432
Brake Fluid Flush 3yr/50k
Power Steering Fluid Replacement/Flush Every 100k or 5 years
*Special Considerations*
All Series II/III 3800's RPO's: L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
Lower Intake Manifold Gasket Replacement, every 80-100k (ignorance of this can allow coolant to enter your engine oil, this happening can cause irreversible lower engine damage, requiring replacement of subject engine)
Series II, Naturally Aspirated, RPO:L36:
Upper Intake Manifold Plenum Replacement, Every 80-100k (ignorance of this can allow coolant to enter your intake manifold, possible damage to occur can be hydrolock, irreversible damage to emissions devices, misfires, etc. Most times, engine replacement is required if ignored long enough.) viewtopic.php?f=53&t=1061
Series I, II, III RPO Code L67 & L32:
Change Supercharger Oil; Every 30-50k. (Intense Racing or GM Dealer) viewtopic.php?f=56&t=1690
Supercharger Belt; Inspect Every 15k, Replace Every 100k or as needed.
- nos4blood70
- Year and Trim: 2003 SLE
Re: power?!
Could be anything really.
bonnie33
- LE Member
2003 bonneville se
Re: power?!
ive had the car for exactly a year now, it has new engine about 70,000 miles on it, but the thing is i dont know any of the maintenance done to it, i looked at the air filter and its terrible so im getting one, but id have to check everything else, what happens is i tried putting it to the boards with tcs off and no tire squeak or anything, barely puts you back in your seat. im thinking its the higher gear ratio.
- repinS
- Moderator
- Year and Trim: 09 G8 GT
Re: power?!
I'd be curious to see what final drive ratio you have.
Does anyone know what RPO codes we need to be looking at? Or better yet, what are your RPM'S at 60mph?
94SilverSSEi
68 w/400
Re: power?!
repinS wrote:I'd be curious to see what final drive ratio you have.
FW2 or F17, I believe.
Clay
