Got it back home, replaced it with a new one, and everything seemed fine. I've put a few hundred miles on it, and it runs perfect with the exception of one problem..
If I floor it, it feels more like it is at half throttle. Not only that but I can floor it, say doing around 25-30mph in 2nd gear, and it won't downshift to 1st... Or if I'm doing 50-60 and floor it where it should downshift to 2nd, it only goes to third. I've tried manually downshifting and it will go to 2nd, but there is still no power... It's as if I've got it at half throttle.
Now from a dig I can floor it and it will wind (very sloowly) up to redline then shift to 2nd.
I replaced the TPS with the one from the donor motor, and even tried a junkyard one... No luck. No SES lights. The only other thing I can think of is today I noticed right after I started it and began to back out of a parking space a couple of times, it would cough and sputter until I jabbed the throttle, then cleared up. Other than trying to romp on it at WOT, it drives perfectly normal.
I'm kinda stumped..
I'm betting (and hoping) it's something stupid simple that I overlooked.
