It's red.
It's 21 years old.
It's manual.
It's quirky.
It's got some utility.
It gets 30+mpg all day, every day.
It's FWD.
Any guesses?
Could be an older GTI. They handled great back then according to Top Gear and other magazines.BonneMe wrote:AutoX machine gave away CRX.
If it is, awesome. They are so much fun to drive.BonneMe wrote:AutoX machine gave away CRX.
Jerry would buy a CRX long before a '91ish GTI. CRX's are pretty wicked at AutoX with a couple grand tossed at them..PRD2BDF wrote:Could be an older GTI. They handled great back then according to Top Gear and other magazines.BonneMe wrote:AutoX machine gave away CRX.
B - Stock Class
All normally-aspirated Front Wheel Drive cars and 4-cylinder All Wheel Drive cars. Only allowable modifications are listed below.
B - Stock Plus Class
All Front Wheel Drive "R-Type" cars (Integra R, Civic SiR, Neon ACR, etc.) Front or All Wheel Drive factory forced induction (i.e. turbocharged/supercharged) cars under 2.0 litres in engine displacement and normally aspirated All Wheel Drive cars with more than 4 cylinders. Only allowable modifications are listed below.
B - Modified Class
All Front/All Wheel Drive cars with modifications not permitted in Stock class. No internal engine or boost modifications allowed.
Allowable Modifications for All Stock Classes
Any make and size of tire and wheel combination. (2% time bonus for street tires)
Any make of shock absorber/strut assembly, including adjustable shocks.
Any modification of the exhaust system from the manifold back (no modifications to the manifold permitted).
Any modification to the air intake system. Modification and/or replacement of the Throttle Body (fuel Injection) or Carb not permitted, unless the substituted part was available as an option through the OEM manufacturer for that engine.
Larger sway-bars permitted provided they were available as an option through the OEM manufacturer for that car (must be Dealer option).
Any alignment adjustment within OEM specifications.
