Seized Rear Brake Caliper Bracket Bolt
Posted: Sat Jan 07, 2012 4:23 pm
by candybonne
I have to change my rear wheel bearings to pass inspection. I can't get the caliper bracket bolt loose. I have tried a breaker bar. Banged it with a mini sledge hammer and nothing but an almost stripped bolt and a busted 15mm socket. I know if I strip it. The whole control arm is going to have to come out. I have soaked it in PB Blaster although I don't think it will do any good since the bolt threads are not exposed. Any suggestions or should I keep banging on it until I bust all of my knuckles? Has anyone else had this issue?
Re: Seized Rear Brake Caliper Bracket Bolt
Posted: Sat Jan 07, 2012 5:39 pm
by crash93ssei
Biggest thing I would say is make sure you are using a 6 point socket and not a 12 point.
Posted: Sat Jan 07, 2012 9:20 pm
by candybonne
Thanks! I got it off eventually. I always tend to forget that paitence is key when using PB Blaster. It works wonders. Stumbled into a brake job too. I refuse to put back on crappy stuff. So it'l be up in the air for two days.
Posted: Sat Jan 07, 2012 10:06 pm
by Ryan from Ohio
Got an impact? Even the cordless one like a drill.
Posted: Sat Jan 07, 2012 11:44 pm
by candybonne
Nope I need an impact. I kinda enjoy the upper body work out though.
Posted: Sun Jan 08, 2012 10:07 am
by Ryan from Ohio
I understand, but the multiple fast shocks will break it loose before shear force.
Got any heat to put on it? I use a plumbing torch. You can pick those up fairly cheap at Lowes/Home depot maybe even Walmart...?
Posted: Sun Jan 08, 2012 12:50 pm
I believe he got it out.
Posted: Mon Jan 09, 2012 12:38 pm
by rustyroger
He got it out but still some good advice for anyone with a stubborn bolt here.
Roger.
