Now getting a randon surging tach and then die at stop sign
Mac077
- Posts like an LN3
- Year and Trim: 2000 SSEi & 2005 SE
Since I had my radiator issue and replaced it I am now getting a random issue with my '00 SSEi stalling at stop signs/lights! Not all the time but at random times it will do it for a while until I shut it down and let it sit for a while. Any ideas? No messages thrown from the DIC or dash accept to check tire pressure! It is running rough when this happens too and it has been running rough for a while especially at very low RPM's. Thanks
2000 SSEi (Silver Eagle) cleared corners (before accident) new LIM gasket, drilled 180 T-stat, new plugs and wires, new valve cover gaskets, new Supercharger gasket, third brake light overlay. Hopefully soon to start more mods for performance. Also, 2005 White SE totally stock and will remain that way!
Thank you Bob & Vince for your hard work and kindness!!
Re: Now getting a randon surging tach and then die at stop s
Almost sounds like a crank sensor to me.
Mac077
- Posts like an LN3
Could my previous issue had anything to do with it and what exactly is it?
- Year and Trim: .
Probably not, but it is located behind the harmonic balancer on the crank. The very bottom pully in the center of the motor.
After it stalls and does not start, does the tach move while trying to start it?
Mac077
- Posts like an LN3
It starts right up after it stalls, just stalls again at the next light, and at the next light, etc. unless I keep it revv'd
Ken_W
- Posts like an L27
Fuel system problem perhaps? When was the last time you changed your fuel filter?
Have you ever replaced or at least cleaned your MAF sensor?
It looks like you've done a lot of work on your car; can we assume that all regular maintenance is up-to-date?
(Shooting from the hip here -- more-knowlegable folks may have a better idea.)
Ken_W
Ken_W
- Year and Trim: .
If it is not in gear (setting in the driveway) how does it idle? Do you have any way of checking the codes?
Ken_W
- Posts like an L27
He said he was not getting any codes.
- SSEiMan01
- Year and Trim: .
03 PAU - Location: DeKalb, IL
Could very well throw a code and not a light, for a variety of reasons
I'm interested in seeing how this plays out, its almost exactly what my 94 was doing...We never found out before it got hauled away...
James May wrote:Hello.
Mac077
- Posts like an LN3
Ok, more info...I just recently replaced the MAF sensor, just put the FWI back on after getting it smogged, just replaced the water pump and thermostat (180 drilled), just finished replacing the radiator (cracked on opposite side of filler), new belts...all within the last year or so. Fuel filter, plugs, wires were last done a couple of years ago when the LIM was done.
And another bit of info that I just thought about...it seems to run fine when cold. It has only done the stalling thing when it is hot outside and the engine is at temp. Hope this helps the thought juices!!
- Archon
Perhaps a plugged cat? Is the performance really bad during this time, too?
Mac077
- Posts like an LN3
You may be on to something there because my cat has been rattling for a while...it does run rougher during these times. I didn't realize it could make that much difference but it makes sense! I hate it because it was also replaced just a couple of years ago.
My dads old car had this same thing and it was the torque converter not working properly (locking or not unlocking cant remember) and it would stall the motor.
2002 SSEi "Raptor"
3.4, Headers, custom Cat-back, HP Tuner, 180 T-Stat, Intense FWI, Mild S/C porting, Autolite 104's, Belden Wires
01bonneSC
Id start with a Cat....
- Year and Trim: .
Mac077
- Posts like an LN3
Ok, does Magnaflow make one for California emissions?? Because this last one sure didn't last long!
Mac077
- Posts like an LN3
Bump
- Year and Trim: .
from here: viewtopic.php?f=18&t=28254myfirstbonnie wrote:I just looked at my receipt and mine is actually part number 46006 which is the California OBD II compliant one. I have had it for 2 years with no issues and I paid $120 for it and welded it in myself when I did my headers.
http://www.google.com/search?q=magnaflo ... 80&bih=744
Mac077
- Posts like an LN3
Good news is it wasn't the Cat...just had it checked and it was good to go. The rattling is apparently coming from the down pipe? Has anyone had this happen? Apparently the are double walled and something must have come loose on the inside?? Anybody???
If indeed that is the case does anyone have a down pipe they can sell me for a reasonable price? Haro, you got one handy?
- Year and Trim: .
The downpipe has a big bubble in it. This is actually the flex section and they do tend to leak.
