Caliper covers or painted calipers
JG2000SE
Year and Trim: 2000 SE
Post by JG2000SE »
Hey guys, I was wondering if anyone has caliper covers on their vehicle and, if so, where did you find them? Did some searching around and didn't have much luck.
If covers don't work, anyone have painted calipers? What type of paint did you use? Any suggestions? I was thinking a simple red to match badging, nothing crazy.
Thanks for any input.
2000 Bonneville SE- Galaxy Silver Metallic - Gutted Air Box - K&N Filter - 20% Tint - 77k miles
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Re: Caliper covers or painted calipers
Post by 01bonneSC »
Whats a caliper cover?
Ive painted mine,
I used the Dulpicolor hi-temp engine paint WITH ceramic. Held up nicely, they also have a caliper paint kit, it brushes on IIRC.
JG2000SE
Post by JG2000SE »
I've also seen them called Caliper Dust Covers. Just a piece of heavy duty plastic that goes over the caliper to protect it and give it some color. Looks like there are alot of scams out there but MGP or MPG makes some but they are approx. $200 for a set of four. Maybe painting is the best way to go?
willwren
Post by willwren »
Engine paint will not stand up to most brake cleaner products.
Use Dupli-Color CALIPER paint. It's epoxy-based and is impervious to brake cleaning solvents and brake fluid.
Ghosthawk
Year and Trim: 2004 SLE
Post by Ghosthawk »
I think the caliper covers are way over priced for what you get. I've painted calipers on three different cars and they have all held up very well. Cleaning and prep are key to lasting results.
I used a wire brush on my drill to remove and surface rust and other build-up.
I then cleaned with mineral spirits and let dry.
Then a primer coat,let dry until tacky
Then color coat
I then wait a 2 hr minimum before re-assembly
I ordered rotors and pads for my car this week, so I'll be doing mine soon.
2004 Bonneville SLE "Bonnie the Ghosthawk" or the 4dr Firebird...Gone but not forgotten
The Blog, http://www.tobthebat.wordpress.com
Luna LeMans on Smashwords
https://www.smashwords.com/books/view/870754
Luna LeMans in Amazon paperback
https://www.amazon.com/dp/1983273589
BonneMe
Post by BonneMe »
I would never cover up calipers with covers, they need to breathe, and be properly cooled by air moving through the wheels.
97SEBonnevilleMan
Year and Trim: 1997 SE
Post by 97SEBonnevilleMan »
:usa: Forget the covers,your brakes need to cool .The Duplicolor brake kit sells at most auto part stores and works the best,Prep work is key,do not rush and make sure you have everything you need before you start......Clean every part well and you should have a smooth finish with light coats of paint not heavy ones...... :) Aloha Matt
alan
Year and Trim: 2005 Pontiac Bonneville 4dr Sdn GXP
Post by alan »
painting them isnt a hard job; and yes is the most feasible color!
[url=http://1stdebtmanagement.com/]http://1stdebtmanagement.com[/url]
[url=http://1stpetinsurance.co.uk/]http://1stpetinsurance.co.uk[/url]
[url=http://badabingbaby.com/]http://badabingbaby.com[/url]
alan, as much as we appreciate you going through the forum and reading, you don't have to post in every old thread you find interesting. The OP hasn't posted since May in here. Please leave old threads lying unless they're yours and you're updating them. If you really feel the need to comment on one or it helps you, start a new thread and link to the old one.
