180* t-stat
epic_pwn_95
Year and Trim: 99 Aurora 4.0
180* t-stat
Post by epic_pwn_95 »
Why is a 180* t-stat considered a performance mod?
RJolly87
Re: 180* t-stat
Post by RJolly87 »
It is done to keep the engine cooler, and help keep heat soaking down as much as possible. This mod also must be done in conjunction with adjustments to the fan turn on temperature as well, otherwise it will be pointless.
willwren
Re: 180* t-stat
Post by willwren »
Not pointless. Call it less effective. Drilling a bypass hole is also commonly done to make the system work better.
RJolly87
Re: 180* t-stat
Post by RJolly87 »
Bypass hole is also great for bleeding the air out of the system as well.
BTW, post 3000! :woowoo:
ChilinMichael
Year and Trim: 2004 Volvo S60
Re: 180* t-stat
Post by ChilinMichael »
If you are going to do this, look at Intense's 180 T-stat. The opening is 50% larger and allows faster flow. Could be useful :wink: (I have it)
willwren
Re: 180* t-stat
Post by willwren »
Not quite 50% larger......
viewtopic.php?f=8&t=17146&p=182559&hili ... at#p182559
I don't remember the actual numbers I calculated/measured way back when, but it's something more along the lines of 50% more flow at best. Still a dramatic improvement over OEM and most other brands though.
ChilinMichael
Re: 180* t-stat
Ah...good enough. Thanks for the kind correction :)
LeSabre in Buffalo
Year and Trim: 2012 Eco
Re: 180* t-stat
Post by LeSabre in Buffalo »
The "premium" DuraLast t-stat (costs about $8.xx or so) at AutoZone is the same Motorrad big-mouth thermostat that Intense sells. Don almost did a backflip when he yanked that stat out of my old LIM and found out it was available at AZ.
