Hey ppl newb from michigan.
JEzze
- GXP Member
- Year and Trim: 2000 quicksilver SSEI
just sliding by here saying hi,i got a my car yesterday and i'm living it. 01 ssei silver bone stock. Any suggestions for whats first to mod.
DDM tuning HID 6000k hi/lows and fogz
FWI, 180*tstate / 18 inch enkie wraped with potenza run flats , danturs tuned pcm,
Home made motor mount / autolite 605plugs/beldin performance wires. Hogan 3 inch dp w/ magnaflow hiflo cat, zzp plot and 3.4 smoothflow MpS, trans go shift kit, 10 inch gtablet mounted running torque app.
I have a kr issue please help....
Re: Hey ppl newb from michigan.
Welcome!!
Your first stop shouldn't be modding, but instead maintaining.
- 1987-2005 Bonneville / Buick 3800 Maintenance List
Run Seafoam, Chevron Techron or Gumout Regane through gasoline every 5,000 miles.
Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease or Amsoil Grease recommended)
Air Filter Every 15k (Amsoil EaA, Purolator PureONE)
PCV Valve Every 30k
MAF Sensor Element Cleaning/TB Cleaning Every 50k viewtopic.php?f=48&t=1661
Fuel Filter Every 15-25k (Purolator, AC Delco, WIX) http://www.pontiacbonnevilleclub.com/fo ... 45&t=23215
Spark Plugs Every 30-50k (NGK TR55 or Autolite 605) (Never Bosch)
Ignition Wires Every 30-50k (Napa Belden, AC Delco, Autolite Pro, NGK) (Never Taylor or Bosch)
Oil & Filter Every 5-6k or Every 6 months (Valvoline SYNPower, Pennzoil Platinum, or Amsoil )(Mobil1, Purolator PureONE, Amsoil EaO, K&N or WIX) (Never Fram) viewtopic.php?f=45&t=214
*Conventional Oil Every 3k/3 months(API SM/SN rating) (WIX (Napa), Delco or Purolator filter)
Tires: Check Inflation Pressure & Visually Inspect Monthly Rotate Every 6-8,000 Miles
Transmission Flush or Pan Drop Every 15-20k (Always make sure filter is changed when flushed) viewtopic.php?f=45&t=10193
Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Mixes-With-Any Coolant Only) (Never Dexcool)
Oxygen Sensor Every 80-100k (30k for non-heated) (AC Delco or Denso) (Absolutely never Bosch) viewtopic.php?f=48&t=794
Accessory Belt Inspect every 15k, replace every 100k, or as needed
Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only) viewtopic.php?f=45&t=13626
Evap Core Cleaning Whenever Needed (Note: 99 and older only) viewtopic.php?f=45&t=2432
Brake Fluid Flush 3yr/50k
Power Steering Fluid Replacement/Flush Every 100k or 5 years
*Special Considerations*
All Series II/III 3800's RPO's: L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
Lower Intake Manifold Gasket Replacement, every 80-100k (ignorance of this can allow coolant to enter your engine oil, this happening can cause irreversible lower engine damage, requiring replacement of subject engine)
Series II, Naturally Aspirated, RPO:L36:
Upper Intake Manifold Plenum Replacement, Every 80-100k (ignorance of this can allow coolant to enter your intake manifold, possible damage to occur can be hydrolock, irreversible damage to emissions devices, misfires, etc. Most times, engine replacement is required if ignored long enough.) viewtopic.php?f=53&t=1061
Series I, II, III RPO Code L67 & L32:
Change Supercharger Oil; Every 30-50k. (Intense Racing or GM Dealer) viewtopic.php?f=56&t=1690
Supercharger Belt; Inspect Every 15k, Replace Every 100k or as needed.
- BlackHawk99
- Senior Moderator
- Year and Trim: _
Welcome from Grand Blanc! Are you located in Flint?
1oldman
Welcome and follow 00Beasts' list asap especially on the intake manifold gaskets. We want your engine to have a long and healthy life! - BC
- rm25x
- SE Member
- Year and Trim: 2001 Bonneville SLE
Another welcome from Grand Blanc, Just picked mine up last Monday!
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
Another welcome from Michigan, just outside of Midland here
JEzze
- GXP Member
Thanks Everyone, I'm in novi. I have a new trans an engine from gm. All new plugs ,wire, filters flush and gaskets. My only thing left to figure out is the darn heated seats do not work all the time. They turn on then off rig ht away. Anyone have .02 on this?
JEzze
- GXP Member
Thanks Again... Now time 2o search headlights. Id like clear corners..
- BlackHawk99
- Senior Moderator
- Year and Trim: _
Seriously? Where in Grand Blanc. Let's be honest, GB isn't all that big! How ironic to have another GBer on the board!rm25x wrote:Another welcome from Grand Blanc, Just picked mine up last Monday!
smittyingr
- Year and Trim: 2001 3.5 Aurora
Hello from Grand Rapids.
Typing with greasy fingers just finished new head gaskets. Yay.
- rm25x
- SE Member
Grand Blanc Rd and Dort Hwy area.BlackHawk99 wrote:Seriously? Where in Grand Blanc. Let's be honest, GB isn't all that big! How ironic to have another GBer on the board!rm25x wrote:Another welcome from Grand Blanc, Just picked mine up last Monday!
JEzze
- GXP Member
I'm. Realizing how many bonneivilles there are now. I wonder if I spotted anyone on here.
- WhiteArrow3800
- Moderator / Social Dev
- Year and Trim: ___
2009 Pontiac G8 GT - Location: Williamsburg, Va
haha, there are a ton of Bonnevilles up there!
Welcome to the Club!
