2000 Bonneville Steering Wheel Control Switches
rvanwechel
Post by rvanwechel »
Does anyone know the procedure to remove and replace the steering wheel mounted audio controls on a 2000 SSEi? I have replacement switches in hand but I cannot determine how to remove my old ones. I'm not going to save the old ones, so I don't mind tearing them up, but I don't want to destroy the connecting plug which looks like it locks into the switch. I hope this doesn't involve removing the air bag and all that that entails. Thanks.
swampthing
Re: 2000 Bonneville Steering Wheel Control Switches
Post by swampthing »
Actually they just pry right out, the rubber in the wheel is more flexible thenyou would think
Current fleet:
rvanwechel
Great, I'll wait for the weather to warm up a little and give it a try. Thanks much!
You'll probably need to use a small screwdriver to disconnect the connector once you have them out that far... there really isn't enough wiring to pull them out that far.
rvanwechel
Worked great! The wires were a little short on the right-hand side, but I was able to make the connection. A bent-nose plier would definitely have made connecting this side easier.
