quick wideband logging census??
slickbonny
- Year and Trim: 2003 SSEi
ok ive seen a few here and there and just want some bacup opinions. ive needed a wideband for some time now. i wanted the Autometer Phantom to match my boost and fuel pressure gauges but im leaning to the LC-1 right now.
then i was planing on using it through the EGR connector(since my EGR is gone). but have read some problems. cuz i have HP Tuners standard.
so the 2 questions are:
which wideband?(Autometer or LC-1... dont want the UEGO as much as ppl back it up)
and
how should i hook it up?( through the EGR connector for standard, just solo and keep my eye on it, or get HPT Pro to log it)
and
03'SSEi(DD since 07')- S1X, S3 IC, SLP headers, JMB FWI, PRJ rails, 65#'s, 2.9", 19* timing, HP Tuned... 310.3whp/411.6wtq(dynojet/pump gas)... after dyno: E85, 72mm TB, and tuning 2.8"@ 22*... 12.8@111mph(full weight, all season street tires, no track prep)
viper8907
- Posts like an L36
- Year and Trim: 2000 SSEi
Re: quick wideband logging census??
I have the LC-1 Along with HPT Pro, and it works very good. I wouldn't suggest using the Narrowband simulation though. Plan on welding in a second bung for the wideband. It takes 15 seconds or so for the wideband to boot up when you start the car, and the car will run like *shoot* until it does if you're using the wideband for narrowband simulation.
If you can get it to work through the EGR I'd say go for it, otherwise see if you can sell your HPT Standard and upgrade to Pro.
-Tom
2003 Silverado Ext. Cab - Charcoal - 128,000 miles - Stock...for now.
2000 SSEi - Gone, but not forgotten.
slickbonny
k thanks man. i just looked at their site and u can send in the standard interface box with about $250 and they will send u the Pro.
how does the LC-1 hook up to the Tuner?
viper8907
- Posts like an L36
There is a plug with the tuner that you wire a ground and the output from the LC-1 into and it plugs into the tuner. I would try to use the EGR first, because that way you don't have to plug that into the tuner every time, you would be able to get A/F info through the OBDII port.
-Tom
slickbonny
well i read this and it made me worry. Tommy Gloves post, second from the bottom...
i basically just want to be able to see the AFR on the gauge all the time while driving. andd also be able to hook it up to the tuner when scanning to save the logs.
what do u think i should do?
sonoma_zr2
- Retired Gearhead
- Year and Trim: 1999 SSEi
get an aeroforce gauge!slickbonny wrote:well i read this and it made me worry. Tommy Gloves post, second from the bottom...
viper8907
- Posts like an L36
x2, you can run the output from the LC-1 into the Aeroforce as well. Take the money you save from not upgrading to HPT Pro, and get an Aeroforce and run the Wideband through the EGR for the Tuner.sonoma_zr2 wrote:get an aeroforce gauge!slickbonny wrote:well i read this and it made me worry. Tommy Gloves post, second from the bottom...
-Tom
slickbonny
hmm im a little confused here...
y do i need the Aeroforce if i have HP Tuner for scanning?
if i did get the LC-1, id prolly get it in the kit with the XD-16 gauge. r u suggesting to get the LC-1 cable and use the Aeroforce as the gauge?
i guess it would be nice to see maybe AFR and KR on the Aeroforce at all times while driving. but i kinda like the oscillating color on the outer edge of a wideband gauge. and im still unsure about using the EGR. how is yours wired?
I'm a n00b to tuning, so when you say use the EGR, would that just be where the EGR bolts into the header as your mounting, or using the EGR wiring to carry your signal?
sonoma_zr2
- Retired Gearhead
use the Aeroforce as a daily scanning gauge. if you want the pretty xd-16, then use the aeroforce for kr and whatever else. it kinda depends where you are going to mount gauges also. on the 00+ people put them in the upper left air vent. more than 1 gauge and you probably want an a-pillar 2 gauge pod.
yes, using the egr wiring to get the wb signal into the pcm.
So then you just read the EGR reading coming from the PCM?
sonoma_zr2
- Retired Gearhead
the tuner is programed to look for the wb signal on the egr input of the pcm.00Beast wrote:So then you just read the EGR reading coming from the PCM?
- Larz01
- SSEi Member
- Year and Trim: 2K1 GTP
I would get neither of the widebands you're considering. Auto-meter gives you no formula. People have issues hooking up the lc-1.
I have had good luck with the PLX in other vehicles, but personally run NGK.
Yes, just tap the 5v egr input to the pcm, and write a formula for this PID, or you can use A/D inputs.
Just Your Average open loop tuned Ethanol Driven DD's
2k1 GTP: 13.307 @ 104: Headers, 1.9's, Tune
2k12 Impala: Stock
2k12 Impala: Stock
slickbonny
ok, im gettin close to getting this all together for spring. so im liking and leaning more toward the aeroforce now. since i already have 2 gauges in my car(boost and fuel pressure). only have room for 1 more(the middle top vent).
so if i got the Aeroforce, what would i need to get to monitor my AFR?
just the basic LC1 kit here without the gauge?:
http://www.innovatemotorsports.com/xcar ... 9d6229ac84
and then plug 1 of the analog outputs into the Aeroforce?
viper8907
- Posts like an L36
Yes, if you get the aeroforce, you can buy the LC-1 without the gauge.
-Tom
