gxp compass
bonneville dan-o
- Posts like an LN3
- Year and Trim: 2000 ssei
2004 GXP
gxp compass
i installed an amp from a 2003 ssei as mine crapped out. ever since my compass needs to be calibrated about once a day.
not sure whats going on. is it related?
thanks,
Dan
thanks,
Dan
2006 Crown Vic, white P71 interceptor. Push bar, 35% tint.
TRADED IN! 2008 G8 Ignition Orange Metallic LY7, 47k miles, Flowmasters, all options but sunroof.
SOLD! 2000 SSEI Black, 180 t-stat, autolite 104's, 3.4" MPS, custom M&D CAI, 1/8" phenolic S/C spacer, throttle body heat sheild, solid front mount, MSD wires, shift kit, 3rd brake light overlay, cleared headlights, tinted and cleared tails, 20% tint, Syntec, ARP license plate bolts Goodyear Eagle GT's,disabled DRL's, 8000k H.I.D's, pilot angel eye fogs
TRADED IN2004 GXP Black. 53,000mi.... drop in K&N filter, 5000k H.I.D. lows, 8000k H.I.D fogs, switchback 5000K turn signals. cleared headlights. 20% Tint.
bonneville dan-o
- Posts like an LN3
2004 GXP
Re: gxp compass
bump
Re: gxp compass
No clue. Did you accidentally unplug it or something? Could the compass be different and it goes through the amp?
- harofreak00
Re: gxp compass
Wanna try a different compass module? Only pay if it fixes it, if it doesn't, return it.
- Archon
Re: gxp compass
Did you install anything else at the same time? Different speakers, subs, etc.?
bonneville dan-o
- Posts like an LN3
2004 GXP
Re: gxp compass
how much would one cost?harofreak00 wrote:Wanna try a different compass module? Only pay if it fixes it, if it doesn't, return it.
where is it located on the vehicle?
Re: gxp compass
It's under the rear deck or on the back of the backseat, I don't remember which.
- harofreak00
Re: gxp compass
PM sent
its under the rear deck.
- CDawg011
- SSE Member
- Year and Trim: 2001 Pontiac Bonneville SLE
Re: gxp compass
bonneville dan-o wrote:i installed an amp from a 2003 ssei as mine crapped out. ever since my compass needs to be calibrated about once a day.
thanks,
Dan
There is a Rear-Integration module on the back of your rear-seat... I plugged something into this wrong when hooking up a Peripheral iPod adapter (because they didn't know what they were doing and told me wrong) and it reset the compass... Make sure everything is hooked into that correctly... or just make sure there are no wires loose.. and also make sure your amp isn't draining your battery when the car is off.... Make sure the power to the amp shuts off when you shut the car off..
2001 Maroon/Red Bonneville SLE. (Pictures to Come Soon)
My uncle is trying to get me to name my car Suzabel.. Pass or Fail?
To all the Mustangs... I can haul @$$ AND a family.
There are only two things I like to see in a bra, and a car is NOT one of them.
Re: gxp compass
The amp is the stock style Amp, and has stock wiring to and from it. I doubt it's not shutting off.
- robjr69
- SSE Member
- Year and Trim: 1996 Pontiac Bonneville SE
Re: gxp compass
Move amp or sub away from the back deck. its interferring with the magnetic field for the compass. I had that happen once.
- harofreak00
Re: gxp compass
The stock amp/speakers will not interfere with the compass
- CDawg011
- SSE Member
Re: gxp compass
i was talking about the Sub amp.. not stock stereo amp.
bonneville dan-o
- Posts like an LN3
2004 GXP
Re: gxp compass
the problem seems to have stopped itself...
Hopefully it wont happen again.
thanks for everyones input
