2000 SSEi Roof Leaks
I bought a used Bonneville and when it rains, I get water in my back seat (floor). I have already unclogged the 4 main drain channels, but now I have a wet (inside) windshield. Are there other drain channels I should know about?
- harofreak00
Re: 2000 SSEi Roof Leaks
Only 4 drains. Maybe you have a replacement windshield with a bad seal?
golfyeti
- Posts like an LG3
- Year and Trim: 2000 SSEi
Every available option - Location: Winnipeg, Manitoba
Not sure if you mean that you only blew out debris in the drain lines from up top or if you also checked where the drain tube(s) can come apart in the cabin.
Here are links dealing with known leak problems causing wet floors
sunroof drain line connections become disconnected
http://www.pontiacbonnevilleclub.com/fo ... =43&t=1688
Door rain shield seal repair
http://www.pontiacbonnevilleclub.com/fo ... 43&t=11470
Mark
The Familyman's Trans-Am
Intense 3.4 MPS, Intense FWI, Intense PCM, copper NGKs TR55's, MSD wires, MSD coils, BWD ICM, MagnaFlow High Flow Cat, drilled 180 'stat, solid front mount, Monroe Max Air rear shocks, Moog rear mounts, Moog suspension bushings, cleared front corners, 190,000 miles
kts0347
- Year and Trim: 2002 Pontiac Bonneville SSEI
Maybe your drain tubes from the sunroof became disconnected. There is a drain tube connection under the plastic trim panel on the windshield A pillar. The trim panel is easy to pull off without tools. You can do a visual inspection of the tube there. Or perhaps the drain tube is disconnected right at the sunroof drip pan and water is draining down the A Pillar. It's not usual to find water pooling around the windshield. Much more customary to find it on the floor, even when it originates in the headliner due to overflowing drip pan.
2002 Bonneville SSEi Black on Black
Mods:Black window Tint all around, Infinity Kappa speakers,Custom Headliner and Visors
Underway: cleared corners, smoked tail lenses, 10 disc cd player
