what scanner to buy for 1995 ssei?
Posted: Sat Jul 17, 2010 12:43 pm
by chris c
this surging/stalling/no-start, etc issues are taking all of my time. what scanner or laptop software can i buy for this car?
not so concerned with cost, i just need to get this car running. scanner needs record failed starts and point me toward a solution...
blood pressure is getting dangerously high trouble shooting this car
Re: what scanner to buy for 1995 ssei?
Posted: Sat Jul 17, 2010 3:39 pm
by Boss455
I have an Actron CP9145 which scans a ton of stuff for this car (OBD 1.5, GM's from 94-95 mostly) and read all the codes. It showed KR, tranny temps and a whole bunch of things. It sounds like your PCM may be bad. I chased down a ton of problems and a new computer fixed everything. It may or may not be your answer but may point you in the right direction.
Posted: Sat Jul 17, 2010 4:13 pm
by chris c
i replaced PCM already...
i am at a total loss...
PCM, ICM, counds cleaned, etc..
when car will not start no injector pulse.
the actron you mentioned will help diagnose a non-start issue with no CEL?
Posted: Sat Jul 17, 2010 10:10 pm
by Mechanical Mike
IIRC you have a spare car for parts, did you try swapping the wiring harness that runs between the ICM, PCM, crank & cam sensors?
Posted: Sun Jul 18, 2010 2:14 pm
by chris c
no mike, ido not have a parts car... i would buy a harness if you could point me in right direction...
i have lost too much time making no progress...
