what scanner to buy for 1995 ssei?
chris c
Year and Trim: 1995 ssei
Post by chris c »
this surging/stalling/no-start, etc issues are taking all of my time. what scanner or laptop software can i buy for this car?
not so concerned with cost, i just need to get this car running. scanner needs record failed starts and point me toward a solution...
blood pressure is getting dangerously high trouble shooting this car
Boss455
Year and Trim: 1999 Buick Regal GS
Re: what scanner to buy for 1995 ssei?
Post by Boss455 »
I have an Actron CP9145 which scans a ton of stuff for this car (OBD 1.5, GM's from 94-95 mostly) and read all the codes. It showed KR, tranny temps and a whole bunch of things. It sounds like your PCM may be bad. I chased down a ton of problems and a new computer fixed everything. It may or may not be your answer but may point you in the right direction.
1999 Buick Regal GS
1992 Pontiac Grand Prix 3.1 (the Backup)
2001 Chevy Venture (aka Rosie) Wife's Ride
1994 Pontiac Bonneville SSEi "Black Betty" NOW PACKIN' 2.5" OF FUN! (retired to the junkyard up above)
chris c
Post by chris c »
i replaced PCM already... :angry4:
i am at a total loss...
PCM, ICM, counds cleaned, etc..
when car will not start no injector pulse.
the actron you mentioned will help diagnose a non-start issue with no CEL?
Mechanical Mike
Year and Trim: 99 SSEi
Post by Mechanical Mike »
IIRC you have a spare car for parts, did you try swapping the wiring harness that runs between the ICM, PCM, crank & cam sensors?
2006 Chevy Monte Carlo SS
chris c
Post by chris c »
no mike, ido not have a parts car... i would buy a harness if you could point me in right direction...
i have lost too much time making no progress...
