Not sure if this is the right area
Marshall2469
- SE Member
- Year and Trim: 95 Bonneville SSE
I wrecked my 95 bonne last Saturday
and am trying to figure out how to pull the front bumper out (I crumpled the passenger side) I was gonna hook chains to a tree and try that, then I realized the bumper is fiber glass or something its non magnetic. does anyone have any Ideas how to straighten it?? and does anyone know where to go to get both front quarter panels the and bumper cover.
- sandrock
- Retired Gearhead
Re: Not sure if this is the right area
Front bumper....the cover is urethane, the impact bar is fiberglass. No straightening either of those out.
Marshall2469
- SE Member
Depressing but do you have any ideas for the quarter panels ?
- Year and Trim: .
Can you post a picture of the damage?
- sandrock
- Retired Gearhead
Are you meaning the fenders?
If so...3 bolts on the top, two underneath, 1 inside at the very top of the frame, two inside by the door hinge, and an attachment point up front. In order to get to the inside nuts and bolts, you have to take off the splash shield.
- WhiteArrow3800
- Moderator / Social Dev
- Year and Trim: ___
2009 Pontiac G8 GT - Location: Williamsburg, Va
The front fenders were plastic and then GM changed to metal fenders, I want to say in '96, might have been earlier. But you'll probably have to replace them.
Try local junk yards or Craigs list, they will probably be your best bet for body panels. Trim level and years between '92-'99 won't matter (SE, SLE, SSE, or SSEi) for the fenders and hood, it's all the same. The bumper cover and reinforcement will have to come from a '92-'95 SSE or SSEi though. Actually, you'd probably want a '95 bumper cover, since '92-'94 had holes for the headlight washers.
- repinS
- Moderator
- Year and Trim: 09 G8 GT
Metal started in 96. I have that random unexplained crack in mineWhiteArrow3800 wrote:The front fenders were plastic and then GM changed to metal fenders, I want to say in '96, might have been earlier. But you'll probably have to replace them.
Marshall2469
- SE Member
Thanks guys, I am sending the pics to my pc and will upload them shortly, kinda a odd question but is it a normal characteristic of a 95 to be a little to light in the rear? almost feels bouncy?
Marshall2469
- SE Member
:sad5: :sad5: :sad5:
this is the damage from the wreck any tips for fixing it??
- wake
- Year and Trim: 96 olds cutlass supreme 4 door
pictures arent working
Member # 534.96 olds cutlass supreme SL 4 door 3100 4t60 *3.33 gears* *Fe1* 115K bone stock DD
- Year and Trim: .
Marshall2469
- SE Member
Thanks and sorry showed the picks on mine here they are
hope they work this time
- sandrock
- Retired Gearhead
Hate saying it, but it's a total loss. Take a look at that bumper support and impact strut. It's *dang* near vertical....no way of getting that back to the proper orientation.
Marshall2469
- SE Member
well hate to be stubborn but i hope your wrong tryin to pull the impact bar on monday hoping it pulls some of the sheet metal straighter with it
LeSabre in Buffalo
- Year and Trim: 2012 Eco
The unibody is bent about a foot or so back. It's a loss. There's no straightening that outside a body shop. That I know of...
Best of luck with it!
- harofreak00
I agree, cut your losses and start looking for another car. That one isn't worth the money that will be required to fix it.
