The "Security" on my dash came on tonite.
Doesnt blink at all, just comes on and stays on. Car starts/drives normally.
Havent checked anything yet due to the bad weather. Any ideas???
"Security" Light
- bobfather99
- SSE Member
- Year and Trim: 1995 White Bonneville SE
"Security" Light
188340 Miles as of 06/07/10, still running.........
LIM/UIM Work done 4/23/07 at 145000 miles...
1fatcat
- Posts like an L67
- Year and Trim: before cars
Re: "Security" Light
Most common cause would be a failing ignition lock cylinder. The pelet sensor wires like to break after thousands of lock cylinder rotations. The wires break too close to the cylinder to repair them so you have to get a new cylinder. You can bypass the system for under $5 with supplies from radio shack and a couple hour of work.
- Mechanical Mike
- Retired Gearhead
- Year and Trim: 99 SSEi
The other possibility is the security switch for the trunk lid. Try unplugging it & see if the light goes out.
2006 Chevy Monte Carlo SS
- bobfather99
- SSE Member
Ill check the trunk switch first. Whats it look like???
- Mechanical Mike
- Retired Gearhead
Read Willwren's post in this thread. viewtopic.php?f=21&t=12529&p=138585&hil ... ty#p138585
