"Security" Light
bobfather99
Year and Trim: 1995 White Bonneville SE
"Security" Light
Post by bobfather99 »
The "Security" on my dash came on tonite.
Doesnt blink at all, just comes on and stays on. Car starts/drives normally.
Havent checked anything yet due to the bad weather. Any ideas???
188340 Miles as of 06/07/10, still running.........
LIM/UIM Work done 4/23/07 at 145000 miles...
1fatcat
Year and Trim: before cars
Re: "Security" Light
Post by 1fatcat »
Most common cause would be a failing ignition lock cylinder. The pelet sensor wires like to break after thousands of lock cylinder rotations. The wires break too close to the cylinder to repair them so you have to get a new cylinder. You can bypass the system for under $5 with supplies from radio shack and a couple hour of work.
Mechanical Mike
Year and Trim: 99 SSEi
Post by Mechanical Mike »
The other possibility is the security switch for the trunk lid. Try unplugging it & see if the light goes out.
2006 Chevy Monte Carlo SS
bobfather99
Ill check the trunk switch first. Whats it look like???
Mechanical Mike
Read Willwren's post in this thread. viewtopic.php?f=21&t=12529&p=138585&hil ... ty#p138585
