Does anyone know which cars came with such a system, and what trim lines?
Also, does anyone have an idea of how they're wired in? (Dead plugs, or do you have to run your own wires?)
I'm looking into adding this to my car, but need an idea of where to look for donors
Anyone know about this option?
I know my 98 Buick lesabre has it and so did my 97 lesabre, anymore than that I don't know, I think I would get the factory service manual if you are planing to do this swap onto a H-body will make the wiring much more easy imo.
Grandma's 89 Olds 98 has it. I've got little idea how plug and play it is.
WHITE WHINE - 1992 SSE Supercharged 236.26 ci (.040 Over) 15.090 at 90.2 MPH on old engine w/ slipping trans & melted O2 sensor - Gen 3 M62 and matching TB, Gen 2 Pully, Zillamotorsports Ported LIM, YT 1.72 Roller Rockers, SII FPR & Injectors, Hypertech Thermomaster chip w/ 160 Thermo, TransGo Shift Kit, Infinity/Pioneer Speakers & a 10" Alpine Type R Sub, all the watts, 140 amp Alternator, Ricepipe CAI w/ heatshield, Pilot Angel Eye Foglights, Clear Corners, '02 17" Chrome Bent 5's, Magnaflow F-Body Muffler and Hi-flo Cat, Ceramic Coated Ported Exhaust Manifolds, Fan Override, Monroe Reflex struts, red calipers 2009 G8 GT - Sport Red Metallic, loaded, SOLO Axlebacks, Rotofab Intake, Tuned, autodim mirror, removed intake manifold cover, HSV GTS triple gauge pod, two tone red-hot shifter and HSV SuperSport steering wheel, GXP rear sway bar and diffuser, 3.45 diff and various Camaro suspension bits, LED Taillights
There's the switch in my car but then there is also a "Lamp Control Module" (LCM) that does a lot of the work from what I've read in past when breaking out diagrams, etc... It would probably be somewhat involved, I remember this module being inside the dash somewhat deep.
