Twighlight Sentinel System
krut
Year and Trim: 1987 Buick Electra Limited
Post by krut »
Does anyone know which cars came with such a system, and what trim lines?
Also, does anyone have an idea of how they're wired in? (Dead plugs, or do you have to run your own wires?)
I'm looking into adding this to my car, but need an idea of where to look for donors :)
Anyone know about this option?
Thanks,
Kurt
rogers9c1
Year and Trim: 1999 buick park ave 1996 chevy caprice 9c1
Re: Twighlight Sentinel System
Post by rogers9c1 »
I know my 98 Buick lesabre has it and so did my 97 lesabre, anymore than that I don't know, I think I would get the factory service manual if you are planing to do this swap onto a H-body will make the wiring much more easy imo.
jdronzek
Year and Trim: 1999 Oldsmobile 88 LS
Post by jdronzek »
Mine has it, also my way passed 98 bonne had it as well.
J Wikoff
Year and Trim: 1992 SSE
Post by J Wikoff »
Grandma's 89 Olds 98 has it. I've got little idea how plug and play it is.
ChilinMichael
Year and Trim: 2004 Volvo S60
Post by ChilinMichael »
There's the switch in my car but then there is also a "Lamp Control Module" (LCM) that does a lot of the work from what I've read in past when breaking out diagrams, etc... It would probably be somewhat involved, I remember this module being inside the dash somewhat deep.
