please reply , so my bonne can fly!
bonnelivin'23
Year and Trim: 1995 Bonneville SSEI, Gold
Post by bonnelivin'23 »
What can i do to my 95 ssei to enhance performance without putting too much stress on my other stock parts. Is a SLR chip a good option.I have 130,000; but i baby it. I just bought this one 3 months ago and the only thing ive' done is fluids and a cool air intake. Anyone have any suggestions.
crash93ssei
Re: please reply , so my bonne can fly!
Post by crash93ssei »
I have never heard of an SLR chip, but if it is one of those Ebay chips, stay far away from it.
There are some options for you, but it all depends on your budget. First, make sure everything is up to par. Make sure your ignition system is good, change fuel filter, check fuel pressure etc. You can get a fender well intake from www.Intense-Racing.com that will be MUCH better then a home made cool air intake. Next on the list would probably be a scanner to monitor KR so you can add power. You can get a smaller supercharger pulley and rockers, but I would make sure to get a scanner first. No point on doing those mods unless you know your engine can take it without blowing itself up.
J Wikoff
Post by J Wikoff »
I'm not familiar with the SLR chip. Got a link? www.sinisterperformance.com can do custom tunes for 95's.
A popular thing to do would be put on a smaller SC pulley for more boost. Either the stock pulley from a 92-93 SSEi or supercharged SSE, or a 2.5" from www.pulleyboys.com. Before you do that, though, I'd check to make sure your fuel pressure is within spec (I think they are in Techinfo). You do not want to run lean under higher boost.
Boss455
Year and Trim: 1999 Buick Regal GS
Post by Boss455 »
An Actron CP9145 is a capable scanner for the 94-95 Bonnies as it can scan for KR. Unfortunately, it isn't all that great for 96+ cars though. I bought mine at Amazon.com for $99 shipped. Performance parts are scarce for the Series 1 engines but I found that a 2.5 inch pulley from Pulleyboys did the job. Good increase in power and good quality item. I made sure my car was in full tune with new plugs, wires and a ton of maintenance parts. Don't forget to run premuim fuel too. :)
1999 Buick Regal GS
1992 Pontiac Grand Prix 3.1 (the Backup)
2001 Chevy Venture (aka Rosie) Wife's Ride
1994 Pontiac Bonneville SSEi "Black Betty" NOW PACKIN' 2.5" OF FUN! (retired to the junkyard up above)
RJolly87
Post by RJolly87 »
crash93ssei wrote:I have never heard of an SLR chip, but if it is one of those Ebay chips, stay far away from it.
Hey! Wouldn't you know it!
http://cgi.ebay.com/ebaymotors/SLR-Perf ... ioQ5fVideo
Phantom
Year and Trim: 1998 Bonneville SSE
Post by Phantom »
Most likely all that chip is, is a resistor in fancy packaging so the car thinks it is getting colder air and commands more timing.
98 Bonneville SSE
03 GrandPrix GT
CAI, U-bend delete, Ported L67 TB, L26 PLIM and UIM.
J Wikoff
Post by J Wikoff »
And the effect quickly fades as the O2 sensor sees the mixture is off and the PCM compensates.
tan96ssei
Year and Trim: 1996 SSEi
Post by tan96ssei »
stay away from SLR (ebay chips) as mentioned above they are nothing more than a fancy resistor that makes your car think it is pulling in colder air. also mentioned above the intial affects are short lived as the O2 sensor learns the mix is off then compinsates. so save yourself the headache and look into the sinister performance link mentioned above as they can permanently "trick" your car.
if you purchase this chip your wasteing money. for 30 cents you can buy a resistor and then stick it into the intake temp. sensor pins and save yourself 5 plus dollars. and get the same disappointing results.
Aerospace Propulsion Technician USAF
Airman First Class,
.:Michael Lyons:.
parts available on 96 see thread viewtopic.php?f=27&t=15185
