2010 bonneville?!?!?
screwstonjay713
Year and Trim: 2003 Bonneville SE
Post by screwstonjay713 »
I was surfing the net searching for a new steering wheel for my bonne and ran across a couple sites showing a 2010 bonneville....now being that pontiac is pretty much finished I'm not a believer but what do u guys know about this??? I hope it is true cuz now that my 03 is all paid off now I wouldn't mind adding a new 1 to the family
Here's the link: http://www.allautoreviews.com/auto_revi ... eville.htm
2003 bonneville SE "Tha maroon monsta"- Blacked out tail lights..20inch gitano blades..7.5inch jensen headunit..2 kicker cvrs..2000watt boss amp..clear corner headlights..Red interior lighting..More to come...
http://www.cardomain.com/ride/3160291
myspace.com/screwstonjay
olblueeyesbonne
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Re: 2010 bonneville?!?!?
Post by olblueeyesbonne »
If you read the specs they match up with 1997 specs. I guaruntee you will not find the Bonneville tag on another new car in the near future, and it will no doubt come with an engine that is not a pushrod 3.8L, which GM already stopped production of. Not to mention, the hp and torque #'s don't match a supercharged 3800 specs and I guaruntee no more SSEi's like they are saying the '2010' model is -the year designation changes with whatever year you are looking for I'd be willing to bet.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
Water 97SSEi
Year and Trim: 1997 SSEi
Post by Water 97SSEi »
Those sites are simply designed to attract search engines, and therefore more traffic, and more ad revenue. I don't consider sites like that one or similar sites to be remotely legitimate.
1997 SSEi | Bright White | 170,000+ Miles | Stock | Best 1/4: 15.374
petraman
2013 Audi A4 6MT
Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
Post by petraman »
Since Pontiac is dead by the end of the year, it's pretty much guarrenteed there will never be another Bonneville (unless GM brings Pontiac back (doubtful) and they bring back their legacy names (even more doubtful))
Night Crawler
Post by Night Crawler »
like stated above by Water 97SSEi. Those sites are crap, guaranteed if you look up a year of Bonneville or any vehicle with a year it never existed. One of those sites will come up.
FWI, converted low beam bulbs into high beam bulbs, 20% tint all around, MSD wires, NDK TR55 plugs, auxiliary line in, scan gauge, custom FloPro/MagnaFlow Cat back exhaust
2002 Bonneville SE
bonnevillain
Post by bonnevillain »
As mentioned, they are just to pull people just like you in from searches and get more money from ads.
