I was surfing the net searching for a new steering wheel for my bonne and ran across a couple sites showing a 2010 bonneville....now being that pontiac is pretty much finished I'm not a believer but what do u guys know about this??? I hope it is true cuz now that my 03 is all paid off now I wouldn't mind adding a new 1 to the family
Here's the link: http://www.allautoreviews.com/auto_revi ... eville.htm
2010 bonneville?!?!?
screwstonjay713
- Year and Trim: 2003 Bonneville SE
2003 bonneville SE "Tha maroon monsta"- Blacked out tail lights..20inch gitano blades..7.5inch jensen headunit..2 kicker cvrs..2000watt boss amp..clear corner headlights..Red interior lighting..More to come...
http://www.cardomain.com/ride/3160291
myspace.com/screwstonjay
- olblueeyesbonne
- Retired Moderator
- Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT - Location: Sauk Centre, MN
Re: 2010 bonneville?!?!?
If you read the specs they match up with 1997 specs. I guaruntee you will not find the Bonneville tag on another new car in the near future, and it will no doubt come with an engine that is not a pushrod 3.8L, which GM already stopped production of. Not to mention, the hp and torque #'s don't match a supercharged 3800 specs and I guaruntee no more SSEi's like they are saying the '2010' model is -the year designation changes with whatever year you are looking for I'd be willing to bet.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
- Water 97SSEi
- Posts like an LG3
- Year and Trim: 1997 SSEi
Those sites are simply designed to attract search engines, and therefore more traffic, and more ad revenue. I don't consider sites like that one or similar sites to be remotely legitimate.
1997 SSEi | Bright White | 170,000+ Miles | Stock | Best 1/4: 15.374
petraman
2013 Audi A4 6MT - Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
Since Pontiac is dead by the end of the year, it's pretty much guarrenteed there will never be another Bonneville (unless GM brings Pontiac back (doubtful) and they bring back their legacy names (even more doubtful))
2013 A4 P+ ------------------ Glacier White Metallic
6MT, Sport Pkg, JHM Stage 1 Clutch/LWFW, JHM Short Shifter, JHM HFC, USP SS Clutch Line, CR-15 Strut Bar, Alu Kreuz, BFI Shift Knob, EC Trans Mount Insert, VCDS tweaks.
- Night Crawler
- Posts like an L36
- Year and Trim: 2002 Bonneville SE
like stated above by Water 97SSEi. Those sites are crap, guaranteed if you look up a year of Bonneville or any vehicle with a year it never existed. One of those sites will come up.
FWI, converted low beam bulbs into high beam bulbs, 20% tint all around, MSD wires, NDK TR55 plugs, auxiliary line in, scan gauge, custom FloPro/MagnaFlow Cat back exhaust
2002 Bonneville SE
bonnevillain
- Year and Trim: 2002 SLE
As mentioned, they are just to pull people just like you in from searches and get more money from ads.
