Timing Belt/Chain??
billberry12
Year and Trim: 2001 SE 130,000 miles.
Timing Belt/Chain??
Post by billberry12 »
Do these 3800 engines need to have a timing belt change at some point as preventative maintainence like the Japenses makes do?
Thanks,
BIll
2001 SE
130,000 miles. All but 11,000 are mine.
Want to drive it another 130,000! Any tips are welcome.
crash93ssei
Re: Timing Belt/Chain??
Post by crash93ssei »
The camshaft is chain driven, but I don't know the change interval on the chain and gears, or if there even is one. I know that our '03 SSEi has 163,000 on the original chain and I am not even a little worried about it. I will probably change it sometime before 200,000 miles though just because.
billberry12
I thought so..just being sure...thanks.
2001 SE
Bonneville92V688
Year and Trim: ‘12 Jeep Grand Cherokee Overland Summit
Post by Bonneville92V688 »
Yeah, no worries. Some earlier 3800s have went 300k+ without a timing chain replacement. And if you are curious, these engines are non-interference, like most pushrod engines are.
Most Japanese engines are OHC, which almost all of them are interference, which is why they strongly recommend replacing the belt when they say it's time.
1996 Thunderbird LX - 3.8
billberry12
What do you mean by "these engines are non-interference"?
2001 SE
crash93ssei
That means that if the timing chain were to ever break, causing the camshaft to stop spinning, the pistons would not come up and slap the valves causing you to need headwork.
Bonneville92V688
Yeah, in a interference engine, if the timing belt/chain snaps, the valves will collide with the pistons, usually bending valves, cracking the head, damaging pistons, and scoring cylinder walls from pieces of the broken valves. It's not pretty.
billberry12
This is good news. One less thing to worry about.
2001 SE
CMNTMXR57
Post by CMNTMXR57 »
crash93ssei wrote:That means that if the timing chain were to ever break, causing the camshaft to stop spinning, the pistons would not come up and slap the valves causing you to need headwork.
Most modern, multi-cam engines do have a safety mechanism that once cam drive pressure is lost (generally by some tensioner, they automatically close all valves in order to save them from kissing the tops of the piston
2011 Camaro SS
crash93ssei
First I have heard of that, it sure would make life a little nicer :) Do they use some type of solenoid or something?
WhiteArrow3800
Post by WhiteArrow3800 »
Our 3800's have a chain tensioner as well. If the chain ever does stretch over time, the tensioner will keep it in check.
Though I have another theory about the tensioner, but that's another topic...
CMNTMXR57
Post by CMNTMXR57 »
Most of them (GM as that's what I worked on) had a mechanical tensioner that when their was a break, let the cams free wheel to shut the valves. It's been awhile and I can't find any technical writeup on it.
2011 Camaro SS
Post by Jrs3800 »
Lets be careful with what we are saying here..
Most of the 8.5 : 1 compression 3800's can survive if it jumps time, but thats no promise that you won't impact a valve if this were to happen..
The 93-95 Vin L engine is a 9.0 : 1 compression, so it has a shallower dish in the piston.. The Vin K and Vin 2 3800 NA is 9.4 : 1 compression and is almost a flat top piston..
Lets have an example... If you were running 80 Mph down the interstate and Poof the tensioner breaks and the chain jumps.... You would have a very good chance of impacting a valve..
The Nylon coated gears used in the 86-87 FWD LG3 3.8 was more than known for jumping time.. And in the worst cases valves were crushed, pistons and heads were destroyed..
These may be called non interference, but that doesn't mean it won't happen.. The 3800 designs have improved and this should not happen, but its not out of the realm of possibilities..
crash93ssei
I know about the tensioner, but won't at least one of the valves still be open somewhere? Is there any one spot on the cam that will allow all of the valves to be closed at the same time?
