front hub replacement
- lackawanna1701
- SSEi Member
- Year and Trim: 1993 SE
Im about to replace my front hubs on both sides... any pointers? She's making a loud grinding noise as I rool down the street. Sorry for asking the same question soo many times just unsure on the whole thing.
Re: front hub replacement
Make sure you have the large socket for the axle nut. It's 34 mm, IIRC. Just take your time, and do one side at a time.
- BlackHawk99
- Senior Moderator
- Year and Trim: _
Moved since this is a mechanical issue.
- willwren
- Retired Admin
- Year and Trim: .
34mm socket at a LONG T-55 torx. You'll need a big breaker bar or a good impact gun.
- 2000Silverbullet
- Retired Gearhead
I was also getting ready to replace both hubs. How long of a T-55? The one I was going to use is only 1" long.
- irkwerks2
- SSE Member
- Year and Trim: 1999 SLE L36
mine was about 3" long (torx bit
)... Might want to check out your ball joints while your there....$50.00 more and all the disassembley is already done.
- Archon
I just used a standard 3/8 drive bit, with an extension. As long as the bit fits through the large hole in the hub, that should work.
- 2000Silverbullet
- Retired Gearhead
That's what I got and what I'm gonna try. Thanks.
- lackawanna1701
- SSEi Member
ima start tomorrow on the driver side hub (all I could afford this week) boss knows a guy at united auto parts... he has a set off an 02 divlle they have 40,000 miles under there belts. Cheap! Can I lube them? If so with what? It amazed me to see that a hub off an 02 would fit on my bonnie 9 years its senior. Wierd
No, it's a sealed assembly. They're not like old bearings, where you take the assembly apart and pack the bearings, and when they went bad, they were cheap.
