front hub replacement
lackawanna1701
Year and Trim: 1993 SE
Post by lackawanna1701 »
Im about to replace my front hubs on both sides... any pointers? She's making a loud grinding noise as I rool down the street. Sorry for asking the same question soo many times just unsure on the whole thing.
Re: front hub replacement
Make sure you have the large socket for the axle nut. It's 34 mm, IIRC. Just take your time, and do one side at a time.
BlackHawk99
Senior Moderator
Senior Moderator
Year and Trim: _
Post by BlackHawk99 »
Moved since this is a mechanical issue.
2012 Ford Fusion SEL, 2012 Chrysler Town & Country, 2007 Chevy Silverado LT, 1999 Pontiac Firehawk, 1979 Pontiac Trans Am
willwren
Post by willwren »
34mm socket at a LONG T-55 torx. You'll need a big breaker bar or a good impact gun.
2000Silverbullet
Post by 2000Silverbullet »
I was also getting ready to replace both hubs. How long of a T-55? The one I was going to use is only 1" long. :sad:
irkwerks2
Year and Trim: 1999 SLE L36
Post by irkwerks2 »
mine was about 3" long (torx bit :) )... Might want to check out your ball joints while your there....$50.00 more and all the disassembley is already done.
Archon
Post by Archon »
I just used a standard 3/8 drive bit, with an extension. As long as the bit fits through the large hole in the hub, that should work.
2000Silverbullet
That's what I got and what I'm gonna try. Thanks.
lackawanna1701
ima start tomorrow on the driver side hub (all I could afford this week) boss knows a guy at united auto parts... he has a set off an 02 divlle they have 40,000 miles under there belts. Cheap! Can I lube them? If so with what? It amazed me to see that a hub off an 02 would fit on my bonnie 9 years its senior. Wierd
No, it's a sealed assembly. They're not like old bearings, where you take the assembly apart and pack the bearings, and when they went bad, they were cheap.
