94 Turn Signal Stalk Yoke Replacement.
2000Silverbullet
Post by 2000Silverbullet »
Someone broke it off today! :angry7:
I'm sure it was an accident.
It's hanging off by the wires.
So how big a deal is it to replace and where's the best place to get one?
Last edited by 2000Silverbullet on Sun May 03, 2009 2:09 pm, edited 1 time in total.
Ragsdale
Year and Trim: 06
Re: 94 Turn Signal Stalk replacement.
Post by Ragsdale »
I have one in my garage, was going to replace the one on the 96 but couldn't figure out how to do it so I gave up.
2000Silverbullet
Is it just the stalk or does it include what the stalk attaches to?
Our actual stalk looks OK but I think it has broken away from whatever it was attached. Too dark now, so will have to look at in the morning.
Does any other gearhead out there have an assembly pictorial?
Bob Dillon
Post by Bob Dillon »
2000Silverbullet wrote:Is it just the stalk or does it include what the stalk attaches to?
Here's a link on steering column repair. There's some info on the turn signal stalk.
http://www.pontiacbonnevilleclub.com/fo ... =24&t=9888
Ragsdale
Year and Trim: 06
Post by Ragsdale »
OOOOO link to the gear head section!
2000Silverbullet
That's a great guide to replacing the internal turn signal mechanism.
How does the stalk connect to the steering column?
Could the ball and socket joint simply have been pulled out and can I simply pop it back in?
Greg, you didn't answer my question.
Bob Dillon
Ragsdale wrote:OOOOO link to the gear head section!
Whoops, sorry. Just a subtle reminder of my exalted status here, peasant. :)
Here's a pic of how the switch attaches once the wheel has been removed. Maybe Andrew (Harofreak) will post the entire how-to in techinfo. It's excellent.
2000Silverbullet
I can see now in the light that the mechanism that the stalk plugs into is all loose and floppy, like it has broken on the inside.
Greg, Ragsdale, PM me a price if what you have is what I need
sandrock
Post by sandrock »
HOLD UP, WAIT A MINUITE.
Is the stalk yoke damaged, or just the stalk? if it is just the stalk (no yoke damage), you can easily extract what's left of the stalk without having to tear into the column at all. The wires connect just outside of the collar...you can take off the plastic housing that surrounds the stalk and the tilt stalk and see it right there. Undo that, fish out what's left of the stalk in the yoke, then go hunting for another.
If the yoke IS broke....then scramble some eggs.
:helpsmilie:
2000Silverbullet
What are you calling the yoke?
The black mechanism that the stalk plugs into seems to be broken. The stalk will not plug into it.
I disconnected the stalk and removed it. A broken piece of metal and a 1/16" dia x 1" long steel pin fell out. :???: Also a small blue cap.
Last edited by 2000Silverbullet on Sun May 03, 2009 11:36 am, edited 1 time in total.
sandrock
Post by sandrock »
If that's the case, start diggin'.
The same thing happened on my '93. It was cheaper, and easier for me to do at the time, to replace the entire column than to dig into the original...lock cylinder and all. I then took the pellet from my original key, and put it into the key that came with the column.
2000Silverbullet
THE ENTIRE COLUMN!!!!
No. I just want to replace what's broke.
What I need to know is what the broken ear that the pin connects to is so I can order it or find the piece in a scrap yard.
The plastic piece the stalk plugs into might be OK. It's hanging by some wires.
It's the metal piece that pins it together that I need. Does anyone have a picture of what it looks like? I don't have a service manual.
2000Silverbullet
Re: 94 Turn Signal Stalk Yoke Replacement.
Here are some pics of what I have.
Post by Jrs3800 »
I am pretty sure that requires disassembly
2000Silverbullet
Now that I inspect it again, I'm pretty sure also. :angry7:
Cheap... :angry4: ..flimsy... :angry4: ...crappy...... :angry4: .
I never liked how wiggley and how close it is to leg entry accidents that stalk was from the beginning!
What I'm trying to find out, if someone has an exploded view of components from a manual, what that eared metal part is that has the round pin in it that holds the stalk yoke.
:helpsmilie:
JMH1950
Year and Trim: no longer a Bonneville owner
Post by JMH1950 »
I just checked my FSM and did not find anything that would be of use to you, Paul. No detailed views of any kind that I could find.
wjcollier07 wrote:Darn it John...now you got me thinking mine's not big enough.
2001 F150 a basic six cyl with 5 speed manual trans.
'66 Piper Cherokee 360 CID , 180 hp, 155 mph @ 2500 rpm, drop in K&N filter.
2000Silverbullet
Thanks John, but check again please. In my 00 manual there is a pic of it in Section 2 near the beginning under Steering, except the detail is not the same as the 94. :sad:
JMH1950
Post by JMH1950 »
Sorry Paul, I checked again and there is no detailed diagrams or pictures.
The only mention of disassembly is:
1. Make sure multi function lever is centered in the "off" position.
2. Remove cover.
3. Disconnect cruise control wire at connector.
4. Pull multi function lever straight out.
Even the instructions for inspection and repairs of the steering column don't mention anything about what you're after.
Strange.......... but true.
2000Silverbullet
:angry7: It really doesn't surprise me.
I was searching the Rockauto site and I think I found the part that looks like it for $100.
Tomorrow I'll drive it, using hand signals out the window in the rain, to the GM dealer for him to diagnose and price the repair.
My Jeep has been in the shop the last couple of weeks getting some rust repair done. I have had to refab all the mud flap brackets in stainless steel.
I hope to get it back Tuesday or Wednesday. :sad:
mntnbkr
Year and Trim: '99 SSEi
Post by mntnbkr »
Replacing the entire column will probably be cheaper than a dealer repair of just the mechanism. Swapping a steering column really isn't all that difficult, and they're not outrageously expensive at salvage yards. I bet it would take half the time to replace the steering column as it would to tear down and rebuild the column that you have.
I've swapped a couple before, both in my '86 Monte Carlo SS. Both time because theifs tried to take it and smashed the column. They never found the kill switch though...sorry bastards. I think I paid like $50 or $70 each time.
~Adam
'99 SSEi
'02 Volvo S60 AWD 2.4T
'02 Jeep Liberty Sport
'89 Chaparral 187XL w/ 4.3L I/O Mercruiser
'00 Cannondale Jekyll 900SX
Follow me on twitter: adumb
