abs and trac controll
00superchargedSe
Year and Trim: 2000 Bonneville Se/ Supecharged. Camed, headers, Full Exhasut.
Post by 00superchargedSe »
First i started it and the abs light had came on. Then today i started it and the trac- controll came on. I know there is a sensor that connects to the wheel hub. If that is what is wrong, then what is a good price to replace it.
2000 Bonneville Se. Supercharged, VS Cam, ZZP Headers, 1.0 PCM, 3.5 MPS, Billet Fuel Logs, Ported Supercharger, Machined intake, K+N Cold Air Insert, 3" Downpipe, Dual Glass paks, Maga Cat, 103 Autolite Cold Spark Plugs, 42.5 Injectors, Belden Wires, 20" EQUUS Chrome rims, Toyo ( Proxies ), Lund Hood Scoops, and Full Tint. Est 330 h.p.
New Mods --> 3250 Torque Converter, High Performance Race Clutches, Harden 4th Gear, and Shift Kit.
Re: abs and trac controll
Check the wiring that goes to all 4 hubs. Take the connector off and inspect the terminals for corrosion.
sco99888
Year and Trim: 2001 se non supercharged
Post by sco99888 »
check the fuse,i had same problem fuse was blown.
laxmangl
Post by laxmangl »
when you check the sensors, spray some electrical parts cleaner on them. Worked great for me.
00superchargedSe
took the sensors off and spayed them down. lights still on and also the low-tire pressure light. What next ??
You didn't find any corrosion on any of the hubs?
00superchargedSe
no. they were fairly clean. some guy i was talking to said that it could be a wheel speed sensor ?? idk
Archon
Post by Archon »
It's a rather low level signal, the cleaner the connection, the better. Did they seem good and tight? If everything looks and feels good, then it is likely the wheel speed sensor has gone bad. You'll have to take it someplace that has a scanner that can read which wheel has the problem. Intense sells a good hub for around $100.
00superchargedSe
i had a scaned by a friend and it said the right rear sensor. How much is a fair price for a rear hub?
Archon
Post by Archon »
The rear hubs are more expensive than the fronts. RockAuto has decent prices, and Timken makes a good hub. I'd suggest not to just look for cheap, as they seem to use wheel speed sensors of lesser quality that may only last a few months, and you'll be right back to the same problem.
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
00superchargedSe wrote:i had a scaned by a friend and it said the right rear sensor. How much is a fair price for a rear hub?
There was another post about the whole rear ABS/WSS harness corroding and needs replacement of the whole thing. I know Haro had to do it on his. What im saying is it may not just be the hub.
Here it is....
viewtopic.php?f=18&t=10671
