abs and trac controll
- 00superchargedSe
- Year and Trim: 2000 Bonneville Se/ Supecharged. Camed, headers, Full Exhasut.
First i started it and the abs light had came on. Then today i started it and the trac- controll came on. I know there is a sensor that connects to the wheel hub. If that is what is wrong, then what is a good price to replace it.
2000 Bonneville Se. Supercharged, VS Cam, ZZP Headers, 1.0 PCM, 3.5 MPS, Billet Fuel Logs, Ported Supercharger, Machined intake, K+N Cold Air Insert, 3" Downpipe, Dual Glass paks, Maga Cat, 103 Autolite Cold Spark Plugs, 42.5 Injectors, Belden Wires, 20" EQUUS Chrome rims, Toyo ( Proxies ), Lund Hood Scoops, and Full Tint. Est 330 h.p.
New Mods --> 3250 Torque Converter, High Performance Race Clutches, Harden 4th Gear, and Shift Kit.
Re: abs and trac controll
Check the wiring that goes to all 4 hubs. Take the connector off and inspect the terminals for corrosion.
sco99888
- Year and Trim: 2001 se non supercharged
check the fuse,i had same problem fuse was blown.
- laxmangl
- Posts like an L27
- Year and Trim: 2000 SE, 2008 Trek 3700
when you check the sensors, spray some electrical parts cleaner on them. Worked great for me.
2000 SE: 17" Chrome Grand Prix GTP wheels, Pirelli P-Zero Nero Rubber.
180,000 miles and running smooth
- 00superchargedSe
took the sensors off and spayed them down. lights still on and also the low-tire pressure light. What next ??
You didn't find any corrosion on any of the hubs?
- 00superchargedSe
no. they were fairly clean. some guy i was talking to said that it could be a wheel speed sensor ?? idk
- Archon
It's a rather low level signal, the cleaner the connection, the better. Did they seem good and tight? If everything looks and feels good, then it is likely the wheel speed sensor has gone bad. You'll have to take it someplace that has a scanner that can read which wheel has the problem. Intense sells a good hub for around $100.
- 00superchargedSe
i had a scaned by a friend and it said the right rear sensor. How much is a fair price for a rear hub?
- Archon
The rear hubs are more expensive than the fronts. RockAuto has decent prices, and Timken makes a good hub. I'd suggest not to just look for cheap, as they seem to use wheel speed sensors of lesser quality that may only last a few months, and you'll be right back to the same problem.
01bonneSC
There was another post about the whole rear ABS/WSS harness corroding and needs replacement of the whole thing. I know Haro had to do it on his. What im saying is it may not just be the hub.00superchargedSe wrote:i had a scaned by a friend and it said the right rear sensor. How much is a fair price for a rear hub?
Here it is....
viewtopic.php?f=18&t=10671
