Cleaning a Supercharger, Instide & off car
- bobtaz13
- Posts like an LG3
- Year and Trim: 2001 SSEi
1991 SE - Location: Minnesota
I just pulled the supercharger for a coolant leak, found the inside of the supercharger coated with DEX. This was do to some one not installing it right the last time and the gasket was torn. I want to clean her up good be for i put it back together.
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
- repinS
- Moderator
- Year and Trim: 09 G8 GT
Re: Cleaning a Supercharger, Instide & off car
Moved to forced induction. =)
Are you saying Dex as in a coating of sludge?
- bobtaz13
- Posts like an LG3
no just a burnt on coating (i.e. the DEX was splashing on the hot rotors while the it was running), was looking at using carb cleaner, but don't want to hurt the rotor coating or anything.
- J Wikoff
- Year and Trim: 1992 SSE
Don't use carb cleaner.
What does burnt dex look like?
- bobtaz13
- Posts like an LG3
Like you took the supercharger and filled in with DEX and baked it in an oven. Kinda orange and black at the same time.
- J Wikoff
Is it flaky or globby?
- bobtaz13
- Posts like an LG3
not really either, it is just a coating on baked on DEX, not ever sure if it is hurting anything, just want it to be the best i can make it for now.
- J Wikoff
Obviously, a ripped gasket is/can be a problem. But you're sure it's not just EGR residue?
- bobtaz13
- Posts like an LG3
it has a orange color to is, so that is my gess
- willwren
- Retired Admin
I gaurantee you also have EGR and PCV residue on it, and the DEX is just a thin top layer. It's generally considered best practice to NOT clean the rotors or housing, as the buildup actually makes the supercharger more efficient. But I too would love to see pics.
Ultimately, it's probably best to leave it and let it clean off over time with use. If you MUST clean it up, don't pull it apart until you have some new spare needle bearing grease or are willing to replace your needle bearings. Especially if your supercharger has 100k miles on it or more.
More general repair/troubleshooting info here (sorry, it's mostly complete, but not entirely):
http://www.3800supercharger.net/
