LIM Gaskets, YAY!
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Re: LIM Gaskets, YAY!
Post by 2003 SSEi »
yup, any time Booze, and also look for foregin material (ie rust,) around the gas filler neck. clean that off if any is present
WhiteArrow3800
Post by WhiteArrow3800 »
That's funny, it's gone now. And I didn't even do anything yet. :laughing3:
I can't really look at the cap itself right now cause it's kinda dark and I don't have a flash light but I can look at it once I get home just to be sure. This car only has very minor surface rust underneath, but the gas filler neck might be dirty, it tends to do that in there. Although I did look at the manual and all it had to say about the 'Check Gas Cap' light is that It would come on if the cap doesn't seal properly, unless there is another section about it.
Oh well, thanks again anyway!
lspitzley
Post by lspitzley »
Where did you get the wrinkle paint from? Does it require primer?
I really want to do this to my car when I change the LIM gaskets soon
2000 SSEi, Black. My summer car
Exterior: White pinstripe, White calipers, white grille, 3rd brakelight overlay
Performance: Intense FWI, Slotted rotors
1997 LeSabre, Tan, My winter car.
154k miles
lspitzley wrote:Where did you get the wrinkle paint from? Does it require primer?
X2, but I want to get some light silver paint to do the Cap and Pontiac, but other than that it looks great and I want to do it.
WhiteArrow3800
Not sure that it required primer, but it was Krylon Black Wrinkle Paint. I want to say I ordered it from Summit but it could probably be found at your local auto parts store.
radomirthegreat
Year and Trim: 1994 SSEi 1999 SLE
Post by radomirthegreat »
I coated a few things with it. The can has a picture of a coated surface, and Advance Auto Parts and O'Reilly sell it locally. Auto Zone doesn't. It's very easy to apply, no primer needed, and I like to blow dry the part or put it in an oven at 200º F. That really gets the stuff to wrinkle. You need a fairly thick coat, which will spray on flat, but it will wrinkle with intense heat.
94 SSEi - Project car
99 SLE - Tuned with different parts and such
85 Porsche 944 - Daily driver
68 Chevy C-10 - Free truck! Needs parts.
WhiteArrow3800
I applied three fairly heavy coats and put the hair dryer to it for 5 minutes in between and about 10 minutes after. I was slightly worried I did it wrong or soemthing because it didn't seem to wrinkle until way later.
We're on page 2 now so Here's a couple more close up:
