LIM Gaskets, YAY!
WhiteArrow3800
LIM Gaskets, YAY!
Post by WhiteArrow3800 »
I've been checking the oil every other day as I have been losing about half a quart every 300-400 miles or so. Wednesday afternoon I checked the oil and refilled 'er with a half quart. Before I put the Oil Fill cap back on I noticed some cream colored goo in the cap. I then checked the coolant level and I hadn't lost much if any. But there was definitely some sort of moisture that got into the system.
So first chance I got (Friday) I flushed the coolant out and managed to get the car into the garage. Hell must have frozen over because the Bonneville kicked dad's '67 Cougar out, though it went to the neighbors garage for a couple nights so it wasn't outside. Anyway Friday afternoon I tore everything down.
Found more goo in the top corners of the valve covers:
LIM:
SC:
Under the LIM & LIM Gaskets:
Crank case:
This broke, as well as both coolant elbows :roll:
Nastyness on the Heads (The coolant was mostly Dex-kill mud when I got it, this is after 5 flushes now):
Makeshift bench and top end stuff:
Cleaned and tucked away for the night:
Saturday I spent all day cleaning various parts (Though I did get a late start) :angry7:
The LIM went back on and the rest of the parts were drying over night.
Wrinkle Black:
This is actually just before I realized I had the gold paint in my hands #-o :
Almost finished:
Notice anything? :twisted: :
Sunday I finished everything up. Dad helped with the valve covers.
I was going to paint the inset stripes gold but after the letters came out I didn't want it to clash, this worked out very nice though:
Trying to figure out where the leftover bolt goes. (It was the hidden one lowest on the accessory bracket)
Coming together:
All done, she started around 10:35 PM:
Afterthoughts:
-Should have went ahead and painted the LIM (But didn't really have time to clean it up properly & I thought wouldn't be noticeable)
-The 'Pontiac' should have been closer to the fill cap, forgot those wires go over the end of it.
-Biggest mistake, I should have washed the engine before I started.
-I never checked the plugs, would have been simple to get the rears with stuff out of the way.
-Make sure retaining clips are on the injectors before putting the fuel rail back on, They were the second to last thing to go back on, and that was a real PITA. #-o
-Trans Fluid and ISS replacement is next and then this car should be good to go :banana:
Last edited by WhiteArrow3800 on Mon Dec 01, 2008 1:45 pm, edited 3 times in total.
PRD2BDF
Re: LIM Gaskets
Post by PRD2BDF »
Looks serioulsy bitchin'!
I dig it!
willwren
Re: LIM Gaskets, YAY!
Post by willwren »
Don't expect the wrinkle to provide any benefit in cooling when applied to fiberglass valve covers. However......
It looks D A M N good. Very well done.
Post by Jrs3800 »
Glad you got it done William... And glad to see dad had a hand on the Buick 3800 :)
OH2LS
Year and Trim: 2002 Chevrolet Impala LS
Post by OH2LS »
Looks very good. I see some wrinkle black in my future if I don't go all powdercoat crazy :)
"3.8 Liters of twisted steel and sex appeal" -schmidty on NAIOA
I've got an '04 CompG. Got a Gen V and an intake...... so far
willwren
Post by willwren »
Powdercoat will hold the heat in. Don't do it!
Ok, i'm officially jealous. I may have to do that, when I have the guys over, but then we have to wait for the paint to dry. Or I guess I could have it done and waiting to go back together. Hmmmm.
Anyways, glad to see you got that done and it looks awesome!!
BlackHawk99
Senior Moderator
Senior Moderator
Year and Trim: _
Post by BlackHawk99 »
Awesome! That LIM gasket was nasty.....how many miles on it?
PRD2BDF
Post by PRD2BDF »
Now you know why your heater wasn't working so good...
LeSabreUltra
Post by LeSabreUltra »
Oh lovely...well at least you turned it into a positive outcome! Well done. :)
-Dan
_
_
WhiteArrow3800
I knew why the heater wasn't working. Just getting very aggravated having to flush it out every other two weeks. :angry7:
81,8XX miles. And she got nearly 100 more on her today. Changed the Oil out this morning and it looked decently clean. Also dumped the water out and got the coolant back in the system since I didn't see any leaks.
And Don, well that about the only thing he did. Except pointing a few things out. And he spent about 20 minutes figuring out how the belts went back on (fun to watch, while I have the belt pattern in my hands. He thought it was simple to figure it out without it). My SC Belt was squeaking all day though. This morning I pulled the hose off the coolant reservoir and so water got all over the pulleys, so when I fired her up to head out to class I figured the squeaking was because they were wet. Well turns out the SC belt managed to move (or wasn't placed correctly) one rib outward so it was off a bit. Fixed that easy enough.
One more thing though, anyone know how to reset the *dang* 'Check Gas Cap' on the dash. I hit reset and tried to hold reset but as soon as I push the button it goes back to the MPG setting that I usually keep it on. I started the car last night and forgot to put the cap back on... #-o
My EGR code (P1404) is gone too :banana:
Anyhow, Thanks for the comments guys, the work really pays off when you guys comment on it. :) :) :)
Last edited by WhiteArrow3800 on Mon Dec 01, 2008 11:50 pm, edited 2 times in total.
93-SSE wrote:I knew why the heater wasn't working, lol. Just getting very aggravated having to flush it out every other two weeks. :angry7:
You just press select to clear the messages on the DIC, whether it be check gas cap or service security system. Ask me how I know. :wink:
Pontiac1
Year and Trim: 1993 SSEi
Post by Pontiac1 »
Looks great!The valve covers really came out nice!Tim
radomirthegreat
Year and Trim: 1994 SSEi 1999 SLE
Post by radomirthegreat »
You've got a mightily attractive engine bay. Good job with that wrinkle finish! Air intake going on soon?
94 SSEi - Project car
99 SLE - Tuned with different parts and such
85 Porsche 944 - Daily driver
68 Chevy C-10 - Free truck! Needs parts.
bill buttermore
Post by bill buttermore »
Nice work and good photos. Way to go. :)
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
WhiteArrow3800
Again, Thanks Guys!! :)
Yes Radomir, Intense Level 1 hopefully in January. I was going to do that this month but I'm a little bit pinned down at the moment with the green stuff :roll:
I still didn't get the 'Check Gas Cap' to reset. I just might have to resolve myself to looking through the little red book in the glove box :laughing3:
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Post by 2003 SSEi »
fix the cause of the gas cap error message?? That should make it go away
WhiteArrow3800
The gas cap is definitely on correctly, I've double double checked that. :ack: However I found this morning that the gas door lock quit working again but that doesn't throw a light.
Pushing Reset or Select on the DIC didn't solve it. It comes up every time I start the car and stays until I push a button. Maybe disconnect the battery again, that ought to clear it, but that shouldn't be what I have to do.
Last edited by WhiteArrow3800 on Wed Dec 03, 2008 12:00 pm, edited 1 time in total.
2003 SSEi
LOTS of Mods
Post by 2003 SSEi »
just because the gas cap is on correctly dosent mean anything, There is a seal on the cap, and if that is comprimised then you will get the message on the DIC.
you should consider reading up on this issue in your owners manual for further info
WhiteArrow3800
Oh, ok. I'll have another look at it again, and go through the manual as well. Thanks for the info!
Last edited by WhiteArrow3800 on Wed Dec 03, 2008 12:47 pm, edited 1 time in total.
