Hello,
Although I had my Bonneville GXP for 2 years now, I am new to this forum. I think this is a great thing and very informative and helpful.
Well, I seem to have a problem with my heating. We have now freezing temperatures at night in southern Indiana. When I drive with the AC on auto and the temp. on 72, the car gets nice and warm.
But after an hour or so of driving, ice cold air starts to blow out of the vents. And the only way to stop it seems to switch to the defrost mode and then back to auto.
Any ideas what that might be? Does someone has a similar problem?
Thank you very much, it is great to be here.
Heating System
Pontiac4Life
- LE Member
- Year and Trim: 2005 Pontiac Bonneville GXP
Heating System
2005 Pontiac Bonneville GXP, Crimson Tintcoat
2007 Pontiac Torrent (The wife's ride)
Re: Heating System
It sounds like an airmixb actuator messing up, but usually they work or they don't. Are all the vents the same when this happens? driver & pass?
RJGill84
- Year and Trim: 2001 Pontiac Bonneville SE
Re: Heating System
Something similar to this occurs in my Bonneville w/ the auto climate control too. I think it is just a function of the ACC system though, and is supposed to happen. People who ride in the car comment on the vents blowing out cold air after awhile - however, it seems that they're just circulating air.
People will say to me "turn the heat on!!" because they are used to the different nature of MANUAL climate control - where the heat is BLASTING until you're hot, and then you turn it off or down. Auto Climate Control doesn't operate that crudely. It heats the car to the desired temperature, then throttles the fan and heating down and circulates the air - which to someone used to the manual type, could be confused as cold air coming from the vents. Just a thought - bc that's what it is in my car.
"SLE without the ugly" - leather, climate control, sound, 3.05 gearing, 180* t-stat, tints. http://www.gillsystems.com
- dpnewfie
- Year and Trim: 2005 GXP
Re: Heating System
X2
I fully agree. Its simply a function of auto climate control.
2005 Bonneville GXP, 200k and SOLD!J Wikoff wrote:It has been an honor and privilage to have been serviced by you.
Re: Heating System
I've noticed the same thing (or similar) and set the temp, vents, and fans manually and bypass "auto". The car seems to want to keep the car exactly at the set temp and the heat and AC cycle back and forth on auto.
Pontiac4Life
- LE Member
Re: Heating System
Hey, you guys are great. Thanks a lot. I will try the trick Venom suggested tonight.
What a great community to be in, thanks so much.
RJGill84
Re: Heating System
No problem! Welcome to the Club - they really are a great bunch of people here! Certainly helped me a lot in the last year and a half of membership! You'll find they'll do just about anything they can to help you!
Be sure to check out the Tech Info section, as there is a lot of common issues and solutions explained there!
