security light randomly flashes
bonnevillain
- Year and Trim: 2002 SLE
so i have noticed lately that once in a while, i get a DIN DING DING and if i look down real quick the security light flashes once or twice. i am guessing this is because of the aeroforce, seeing how it never happened before, and thats the only thing i have changed. To be honest, i dont know what 12v line i tapped under the fusebox, all i know is it had 12v acc. power. has anyone else had this problem? do you think switching wires would help? im guessing the aeroforce is drawing too much power from that line, causing whatever is really on that wire to think something is wrong...
Re: security light randomly flashes
I don't think its because of the way you hooked it up, IIRC on the 00+ it will get the random security light periodically because the aeroforce is constantly scanning the data bus.. I'm not 100% on that but I remember reading up on that somewhere.
You should find out what line you tapped into.
Not true.Mickman wrote:IIRC on the 00+ it will get the random security light periodically because the aeroforce is constantly scanning the data bus.
Guess I was wrong, I thought I had read that somewhere.. my bad!
2003 SSEi
- Year and Trim: 2003 SSEi.
LOTS of Mods
harofreak00 wrote:Not true.Mickman wrote:IIRC on the 00+ it will get the random security light periodically because the aeroforce is constantly scanning the data bus.
acutally it is, I contacted Aeroforce, and on the Newer cars 02+ this is a known issue, and they told me almost exactly what Mick posted. Its actually in the Newest Version Instructions
Aeroforce recommended that the scan rate gets set down under 3, and i have, my car still does it, i have learned to live with it
bonnevillain
hhmm. thanks for the info. it never stayed on or anything, so i wondered what was up. as long as nothing is being harmed. i think my scan rate is at 1
dirtracr95
- Posts like an L27
- Year and Trim: 1988 and 1987 Buick Lesabre T-Type
hope you didnt tap into the yellow harness
Doesn't the newest Aeroforce draw current through the OBD port?
bonnevillain
yes but mine is not the newest. no, the line i tapped was not yellow. that's airbag correct?
white06lacrossecxs
- SSEi Member
- Year and Trim: 2006 Buick Lacrosse CXS
Yeppers. If it's yellow let it mellow. LOL
bonnevillain
i was sitting here thinking about this... and on a whim i decided to check my wiring. turns out i did tap a yellow wire, even after thinking beforehand not to
I then tried a gray striped wire, which set a p1626 code, and now a blue wire that seems to work fine. we'll see if the security light still comes on. if not, doesnt sound like its a big deal.
2003 SSEi
LOTS of Mods
it dosnet matter if its a yellow wire, there are tons of them in the car
it matters if the harness loom was yellow
To dredge this back up, I have mine set a 3, with no issues, on my 03.1993 sle wrote:Aeroforce recommended that the scan rate gets set down under 3, and i have, my car still does it, i have learned to live with it
2003blackbonniese
- Year and Trim: 2003 Black bonneville SE
i agree
00Beast wrote:Doesn't the newest Aeroforce draw current through the OBD port?
- 120,xxx miles,180° thermostat, cold air intake with k&n filter and heat shield, CB radio (it's necessary),
- cleared headlights and tail lights, new tires, Sylvania Silverstar* 9005 High Performance high-beams,
- Sony X-Plodes, Scangauge 2
bonnevillain
old thread.. I don't notice this anymore since i installed my aftermarket HU. I didn't buy the expensive harness, so i have no door chimes, and if it just flashes for a split second i don't even notice.
And yes, some draw current from the OBD-2 port, they have a jumper on the back that mine does not.
2003blackbonniese
from what i know this seems to be a common issue-? (i think it is normal)
bonnevillain
IT should not flash randomly and ding, unless you have an aeroforce installed.. AFAIK
