Project Bonneville Begins
Hans
Year and Trim: '07 MDX | '13 TL | '06 GTO
Re: Project Bonneville Begins
Post by Hans »
you dont f**k around do ya!
Boostershot
Year and Trim: 2000 SSEi 1996 Cavalier
Post by Boostershot »
A small update on the project. Managed to get the engine torn apart and well, it didn't look any better after I started cleaning it up :sad5:
I had intentions of replacing the cam anyway, but the stock one is shot, Lifters were thrown out, they all had some serious pitting...guess i need new ones :twisted:
Chipped Cam Lobes are Bad
Cleaned and bead blasted Manifolds, ported the forward Manifold. Cleaned and bead blasted the front/rear engine covers, and oil filter assembly. Decided that with a 115k on the car, a fresh water pump was in order.
Cleaned Front Engine Cover, complete with shop towel!
Rear Engine Cover
Ported the LIM a bit, but it's going to require some JB weld and sanding where that ugly block of coolant decided to make itself at home.
I had also planned on re-using the stock pistons and rods, but having cleaned them up, I discovered what looks like a chip in one of the pistons.
#2 Piston. Chipped?
It's starting to add up, but I'm determined to get to my goal.
Y2K SSEi Fresh L67, 3.2 MPS, XP Cam, ZZP Stage 2 Heads w/105's, CC OeR Lifters, ZZP Stainless Headers, ZZP Downpipe, Catless, 180*T-stat, 104's, Custom CAI, Hptuners
