Headligts ssei 1992
Headligts ssei 1992
Hi is theres a huge diffrens between the headlight assembly on a 92,93 and an .94,95 model ? they look simular on a pick but the list that dont match each others .. is theres some small mods to make them fit or does only the 92-93 model acculy match ?
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
Re: Headligts ssei 1992
'92 - '95 are the same exact headlight and will take no mods to fit. The only difference is that in '92, one of the headlights had "Pontiac" on the outside of it. Makes no difference for fitment though.
- J Wikoff
- Year and Trim: 1992 SSE
There is one difference. The earlier light has a glare guard around the low beam bulb. I've found the newer version without the glare guard to have a more focused beam that provides a better view of the road.
J Wikoff wrote:There is one difference. The earlier light has a glare guard around the low beam bulb. I've found the newer version without the glare guard to have a more focused beam that provides a better view of the road.
well thats an upgrade ,, thats what i like
but i will be pleased by using those newer headlight with separate hi and low beam ( 9005 -9006 ) and complete them with hids ,, i had an 89 oldsmobile cutlass ciera sl earlyer and those Hids did wonder on that car ,, il think this will be the same ,, any suggestions where il can gat a nice pair of headlights then ?
Your car has h4 bulbs in the headlights? Interesting. No, I doubt you will ever find another set like that again. Upgrade to the 9005/9006 style, you should be able to find a ton on ebay.
yepp i´v got H4 and yepp i´v seen lot´s of shops on ebay BUT they does only sell to the "world" and in there WORLD does only US & some times canada exist ,,harofreak00 wrote:Your car has h4 bulbs in the headlights? Interesting. No, I doubt you will ever find another set like that again. Upgrade to the 9005/9006 style, you should be able to find a ton on ebay.
i guess the most common way of a SCAMMER is to use an "alien" account ( Alien=no US people) but heyyy we are not talking about a huge amount of dollars and il pay by pay pal so they always recive money before shipment ,, it´s a mystry to me ,, My dollars has the same value as yours ,, !!
