Engine Surging
gk35
Year and Trim: 1994 Bonneville SE
Engine Surging
Post by gk35 »
1994 Bonneville SE
Several months ago the engine would surge upwards of 3000 RPM on startup and stay there. I pressed the accelerator several times to see if maybe it was stuck, but surge continued. Turned engine off, cleaned the throttle body with carb cleaner and seemed to fix the problem.
Yesterday, drove home from work. Stopped off at a store and returned to the car. Started it up and it surged to ~3000 RPM and did not drop. Managed to drive it the 1 mile home while holding the brakes.
Got home, turned the engine off then on again and no surge.
Any ideas? Another throttle body cleaning? TPS?
96 SSEi
Re: Engine Surging
Post by 96 SSEi »
you can first make sure the throttle plate closes properly.
really should get it scanned for codes and make sure tps is proper
is the ses light on?
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
gk35
Re: Engine Surging
Post by gk35 »
SES light is not on.
Evan0801
Year and Trim: White 1994 Pontiac Bonneville SE, 3800 Series 1.
Re: Engine Surging
Post by Evan0801 »
Replace IAC sensor or MAF. If i had to guess it's going to be the Idle air control
1994 Bonneville SE - Series one. L27
1998 Bonneville SE - Series Two. L36
2001 Bonneville SSEI - Series Two. L67
96 SSEi
Re: Engine Surging
Post by 96 SSEi »
Evan0801 wrote:Replace IAC sensor or MAF. If i had to guess it's going to be the Idle air control
try cleaning it first _ may get lucky
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
