HELP...PLEASE Old fittings to new 1/4" line--can it be done
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
Bought copper nickel 1/4" brake line to replace the lines from the master to the EBCM.
Can't get the darned fittings onto the new line.
Must I buy new fittings or can the existing fittings be drilled out or am I overlooking something in my presently aggravated state?
TIA
Re: HELP...PLEASE Old fittings to new 1/4" line--can it be
You need 3/16" line, not 1/4"
MattStrike
Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
'92 Trofeo
Post by MattStrike »
While I can't speak for what the '00+ stuff came with from the factory, I know that all the '92-'99 came with 6mm lines between the master and ABS module, and 4.75mm lines to each wheel.
All the brake lines in the stores are SAE, so 3/16" (4.76mm) & 1/4" (6.35mm). If you had the 6mm lines, you had to drill out the fitting to get the 1/4" line in. The other fun part is getting a bubble flare tool to fit a 1/4" line. The only other option is to use an adapter that converts the bubble flare fitting to a standard double flare fitting.
I would not drill out a 3/16" fitting to fit a 1/4" line, you lose the radius/shoulder on the end that seals it off and the sharp edge would cut into the line.. So don't do that if your fittings were not originally sized for 6mm line.
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
MKMike
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
harofreak00 wrote:You need 3/16" line, not 1/4"
I have 3/16" line but it seems much too small for those MC line fittings--really flop around on it, so I didn't want to risk it.
Measuring the OD of the OE lines from the master cylinder, it is truly 6mm.
However, it does look like all the rest of the brake lines may be 3/16....unless there's some other bizarre metric line size.
Haro, have you installed copper nickel line in any of the veritable fleet of Bonnevilles you've repaired or do you use factory lines?
I've never used anything besides steel and thought I was giving myself a break :evil:
Yes, indeed.
I went that route yesterday... a few hours after posting. Bought them from Rockauto.
25 feet of 6mm NiCopp with some fittings was actually slightly more expensive than the 2 ACDelco pre-formed lines.
MattStrike, I was truly pretty frustrated at the time I posted ---having expected a relatively brief chore---and wanted to know what others have done when using NiCopp line .
I'm never one to jury-rig at the expense of safety.
You're spot on about flaring, too.
My Mastercool kit only has metric bubble flare dies.
Sage advice, indeed from you gents.
Thank you both!
2000_bonne
Post by 2000_bonne »
MKMike, keep us posted on how the final repairs go and what it took to do so.
As I mentioned, I am soon going to have the enjoyment of replacing brake lines myself.
dougtoth
Year and Trim: 2005SLE CRIMSON
2005SLE PEARL
1975 MONTE CARLO
Post by dougtoth »
My 2000SLE brake lines are starting to look pretty rusty.(surprise here in Wisconsin)
The company I am looking at is Inline Tube located in Michigan.
They have a 9 pc. stainless steel brake set for Bonneville (2000-2005) for $180.00.
Website inlinetube.com.
Phone number (800) 385-9452.
This looks like a good possibility.
Also where have you been lately MKMike?
Thanks.
Doug.
MKMike
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
Sorry for the late reply.
Changing the MC lines was easy enough. In road salt states, soaking the line ends with Kroil is helpful.
Actually needed to cut one line and tap a socket on it to get it removed.
The problem with all the aftermarket lines that I've seen for the master cylinder is that they have no strain relief---they're just solid lines, without any coiled or flexible section--unlike the ACDelco OE parts which have 2 flexible segments per line.
Glad I was missed, Doug.
Had 2 family members hospitalized, more than once, these past few months.
Both are nearly fully recovered now.
dougtoth
2005SLE PEARL
1975 MONTE CARLO
Post by dougtoth »
MK Mike.
Sorry to hear about your 2 family members.
Hope things are now better.
I know how those things take priority.
I lost my father in law in July and my mother in October.
Hopefully 2019 will be a better year.
Does the strain relief make that much of a difference?
If so I guess ACDelco OE parts are the way to go.
