Any pics of a stock CD driver by itself?
DRWBRTq19
Post by DRWBRTq19 »
My current head unit doesn't recognize CDs when they're inserted, its always saying "check cd", even if it's brand new.
And then the other day it hit me that I happen to have a couple extra Pontiac head units lying around (GrandPrix and Firebird style), and I was wondering if its possible to swap the CD drives.
I successfully did this several years back, but they were both Grand Prix units.
So I'm hoping someone may have some pics of a drive out of a Bonneville head unit so I can compare them.
Or even better if someone knows if they're compatible.
Thanks in advance guys.
Drew
Pontiac stable:
2005 Bonneville GXP - Black -daily driver
2004 Sunfire - Arrival Blue Metallic -Wife's
1998 Grand Prix GT - Black -seen better days, awaiting fate
1985 Fiero Sport Coupe - Black (mostly) - long term rebuild
Re: Any pics of a stock CD driver by itself?
Unfortunately only a Bonneville one will work. The Bonneville used a proprietary connector called a Dock-N-Lock, nothing else will work.
I have many good used radios if you're interested, but they must be programmed with a Tech2 scantool or similar.
ddalder
Post by ddalder »
I read this as meaning, can he change the mechanism inside the head unit? Personally, I don't know for sure. Many of the radios seem similar so it may be possible. But, I had some GM radios that appeared to be identical however the part numbers for some internal components were different and were not interchangeable.
Roadrunner
Year and Trim: 03SSEI, 00SSEI, 92SE(sold), 93SSE/SC, 87GTA, 01TA
Post by Roadrunner »
This was my experience with an '00 and '02 Bose.
http://www.pontiacbonnevilleclub.com/fo ... ml#p117813
I found another '02 head unit, swapped the internal CDs and it worked fine.
To save the Tech2 charge you can see if Andrew has a head unit from a Bonneville close to yours and swap the CD into yours.
Dealer Tech2 charges these days can far exceed the cost of the head unit.
DRWBRTq19
Post by DRWBRTq19 »
Yes, the actual mechanism is what I was asking about.
But after looking at Roadrunner's thread, I'm going to have to assume that my '05 is more like the '02 then the '00 style.
On top of that, my drive has a 14 pin connector, so it wouldn't match with either the '00 or the '02.
So probably not my '05 either.
Thanks for the responses guys!
Not what I wanted to hear, but what I needed to.
Drew
Pontiac stable:
96 SSEi
Post by 96 SSEi »
maybe you can bail on the head and go for the 5 disk changer in trunk
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
skregal
Year and Trim: 95 SSEi
05 GXP
Post by skregal »
I replaced just the CD drive in my 2004 Tahoe and it worked fine.
I purchased it from replacementradios.com.
Unfortunately they don't have one for the GXP, as I need one myself.
So if you can find one somewhere, but I think it needs to be the
exact unit, as I had to transfer some wiring and stuff from my old
drive to the replacement.
You could buy the whole unit from Andrew and just swap the CD drive to
avoid the dealer trip and charge.
DRWBRTq19
Post by DRWBRTq19 »
I actually have a disc changer and I love it (save for the fact that it hates bumps and loves to skip, if anyone has thoughts on how to eliminate or just soften this, I'm all ears), but a lot of it just comes down to the convince of not having to pop my trunk t ok change/ add a new disc (ie, me being lazy)
Drew
Pontiac stable:
