2000 Bonnie SE stalling issues
Bad67bird
Year and Trim: 2000 Bonneville SE
Re: 2000 Bonnie SE stalling issues
Post by Bad67bird »
:dontknow: I'll start again monday
1967 Firebird 400 (stock looking but not)
2000 Bonnevile SE (plain)
2004 Grand Prix GT (mildly modded)
Bad67bird
Post by Bad67bird »
MKMike wrote:Bummer.
Well, happy Easter or Passover--or simply have a happy weekend!
No worries Mike , I've been work in on it awile now......thanx for the well wishes and hope you had a happy weekend as well
Jut_D_03
Post by Jut_D_03 »
Lol replace your IAC dude u said you saw Improvement go from there and yes there is a wrong way to install TPS lol almost dos it and tired fuel filter?
Bad67bird
Post by Bad67bird »
So I got all the codes cleared and took her out on the freeway and opened her up to see what
Would happen........at 90 mph WOT the check engine light came back on and I noticed there was
A roaring sound. The code is p0300 random misfire and now when I accelerate hard , it roars like
An open breather.I'm gonna put a vacuum gage on it the see what's up.my thoughts are A : blown
Intake gasket or B: cracked intake.we all see :dontknow:
96 SSEi
Post by 96 SSEi »
just for giggles, unplug the maf and see how she runs
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
Bad67bird
Post by Bad67bird »
96 SSEi wrote:just for giggles, unplug the maf and see how she runs
Lol been down that raod, after two new ones and now an original good one from haro.......no change
Bad67bird
Post by Bad67bird »
Ok I finally found the problem, the Delco ignition module that I put on last year
Had a short in it all along. I found this out yesterday when 3 cylinders mysteriously
Died. Well long story short new module on and problem gone.thanx everyone for the help
And Haro for all the parts lol.
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
Bad67bird wrote:Ok I finally found the problem, the Delco ignition module that I put on last year
Did you mean to say DELPHI module?
I've had some issues with Delphi aftermarket parts but not ACDelco.
Bad67bird
Post by Bad67bird »
No I took Haro advise and ordered an ac delco one to
Prevent problems,but no luck lol
MKMike
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
Bummer. Hope it was just a defective ICM.
There are things you wouldn't even think of which will cause ICMs to keep failing.
One thing I wouldn't have suspected is excessive AC voltage leaving the alternator.
Worse still, the ICM isn't the only component that can get damaged by this.
Just something to check.
You might read this article to get more ideas on this; article is on page 2 columns 2 and 3:http://www.wellsve.com/sft503/counterp_v7_i2_20031.pdf
