1997 Oldsmobile 88 steering shaft replacement issues
Merrillspontiac
Year and Trim: 2000 Pontiac Bonneville SE
Post by Merrillspontiac »
Does anyone have advice on how to replace the steering shaft that goes between the column and the rack and pinion? Tried to replace the shaft and absolutely can not get the shaft to slide back on to the shaft coming out of the column. I'm just wondering if the column needs to be removed in order to do so. If so are there any special procedures as it is a floor shift car? Thanks
1997 Oldsmobile Eighty Eight LS
1993 Buick Regal GS Coupe
1992 Buick Regal Limited Coupe
MattStrike
Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
'92 Trofeo
Re: 1997 Oldsmobile 88 steering shaft replacement issues
Post by MattStrike »
The intermediate shaft, which is has the universal joints, is clamped to the shaft of the column and the shaft on the rack. The bolts have to come out all the way, and then need some persuasion (pry-bar, hammer, etc).
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
