Performance Fuel-rail suggestions
KnightBonne02
- SSE Member
- Year and Trim: 2002 SSEi
Just wondering what aftermarket fuel rails some of youse have on your SSEi
Never getting rid of my Bonnie
Re: Performance Fuel-rail suggestions
Why do you need aftermarket fuel rails?
- nos4blood70
00Beast wrote:Why do you need aftermarket fuel rails?
No need for aftermarket rails.
- MattStrike
- Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
PRJ and Aeromotive (AEI 14131) make them.
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
Aeromotive rails will definitely do the job. You can check them here http://www.carid.com/aeromotive/MattStrike wrote:PRJ and Aeromotive (AEI 14131) make them.
- WhiteArrow3800
- Moderator / Social Dev
- Year and Trim: ___
2009 Pontiac G8 GT - Location: Williamsburg, Va
Wish I wasn't using ZZP crap but I am, these are ZZP's Fuel Logs
I had to trim the mounting brackets to clear ZZP's own intercooler core and as far as Bonnevilles are concerned, if you're running a GXP Strut brace the fuel pressure gauge on the regulator will interfere.
KnightBonne02
- SSE Member
I'm looking for one because I don't like the fact that my fuel rail goes over the supercharger and what do you mean my fuel regulator might interfere
2003 SSEi
- Year and Trim: 2003 SSEi.
LOTS of Mods
zzp uses a huge Fuel Lab Pressure Regulator that mounts on the rear fuel rail
- WhiteArrow3800
Seen here from the back sides. Bottom is the stock fuel rail over the stock supercharger. Top is my GenV with the fuel rails mocked up with the intercooler. The fuel pressure regulator is the black box with the gauge on top, mounted on the rear rail. But again, it's only a problem if you have a GXP strut tower brace.
They all necessarily have to go over the S/C. It's either that or go over the hot exhaust or the moving belt path. That's the most irrational thing I've ever heard.KnightBonne02 wrote:I'm looking for one because I don't like the fact that my fuel rail goes over the supercharger and what do you mean my fuel regulator might interfere
- MattStrike
'04 Dirtymax
'97 Camaro
Nothing wrong with routing the crossover lines under the snout:
Although I'd use 90 degree fittings not 135/45 degree fittings.
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
KnightBonne02
- SSE Member
Yeah those are the ones I seen that I was considering throwing on
